Old 07-12-2012   #1
Daniel_Mc
Daniel_Mc's Avatar
Default GB: DRM Coilovers
Hey Everyone I have been working with Doug Rippie Motorsports (DRM) for a group purchase on the coilover suspension. The DRM coilover set up gives the C4 Race car-level handling, adjustable ride height, and a more controlled ride. The coilover suspension allows each corner of the Corvette’s suspension to react independently by eliminating the leaf springs completely. The DRM coilover suspension can be installed using existing stock shock absorbers or new Bilstein shocks. The group purchase will be for the FX3 or non-FX3 kit without shocks. Other shops sell similar set ups ranging from 2300 as high as 5000. The DRM price for this purchase is 800 shipping included. Here is what you will get:
Four (4) Hyperco coil springs, four (4) billet aluminum top hats, four (4) adjustable sleeves, spanner wrench and polyurethane shock mount bushings. (Shocks not included)
Also DRM has offered the trailing arm and camber brackets at a significant discount. The trailing Brackets 70.00 shipped and the camber brackets at 80.00 shipped.
Please let me know if you are interested this is a onetime only deal and we must have all orders placed by July 27th. Please let me know if you have any questions!
Also our very own Carter (Carter200) makes a very trick set up for the coilover that will allow you to install the coilovers in much less time and best of all keep from all the cutting that was required before. He sells the front sway bar relocation brackets and the rear shock mounting brackets. Very minimum modification to the car is required if using these brackets. Please contact Carter directly if you are interested in the brackets (I would strongly recommend them).
Cheers,
Daniel
Daniel_Mc is offline   Reply With Quote
