12-07-2016 | #81 |
Re: '91 #473 Tuning
sounds like it is time for an ostrich2 emulator so you don't wear out your chip socket.
maybe the lean condition is due to modern fuels?.. or maybe that' how they always were since new. |
12-07-2016 | #82 |
Re: '91 #473 Tuning
Probably a correct assumption! I've got the APU1 so can emulate and tune real time with it, but it's too bulky to leave it installed on a semi permanent basis. Would work well for tuning work however and could then burn a chip "every so often"..
Sent from my XT1585 using ZR-1 Net Registry mobile app |
12-13-2016 | #83 |
Re: '91 #473 Tuning
Need another Montgomery County LT5 to tweak on? I'm getting a little detonation right now...
1991 White ZRJuan #1616 Mileage: 56K Sept-14 -- 113k May-18!!! God Damn I Love This Car! |
12-14-2016 | #84 |
Re: '91 #473 Tuning
Not a fan of "real time tuning" L'd rather collect as much data in as many driving situations as possible and THEN make changes based on overall results. Besides it can dangerous.
12-14-2016 | #85 | |
Re: '91 #473 Tuning
Here's a BLM data log from this morning. This is against stock Port Open VE tables, no modifications. Low kPa low/midrange RPM shows rich. Commanded Secondaries open via BIN table. Gathered data after 25 minutes of driving to achieve stable temp and integrators relatively stable. |
12-14-2016 | #86 |
Re: '91 #473 Tuning
12-23-2016 | #87 |
Re: '91 #473 Tuning
Gents,
Have the VE tables dialed in pretty well now. Passenger side is lean side, driver side averaging about 3 BLM units lower than passenger side. Above 2000 rpm and MAP of 40 kPa, they are only 1 BLM unit apart. 126-127 on driver side and 128-130 on passenger side. WOT work now. AFR pretty steady at 12.5-12.6 from 2200 to 6000 in fourth gear. Seeing some knock retard in this zone. Spark tables at 27 degrees advance. Will pull a degree and re-log to see if I can tweak the knock retard out. Doesn't need fuel since I'm at 12.5+, so will pull some timing and repeat data log. More to come.. Sent from my XT1585 using ZR-1 Net Registry mobile app |
12-24-2016 | #88 |
Re: '91 #473 Tuning
I'm guessing KR is kicking in somewhere around 4500-5500 rpm. U could think about backing off timing in that area depending on how bad the knock is. Altho the motor isn't there for long during a WOT run. BTW, the KR is very conzervative in the cal, so u could reduce the sensitivity and amount as well.
I tried 34d at top end w No Knock detected. I just lost power.
12-24-2016 | #89 | |
Re: '91 #473 Tuning
peace Paul ZR-1 Net Registry Member #1494 |
12-24-2016 | #90 | |
Re: '91 #473 Tuning
Also want timing at where MAP is at its lowest, indicating highest vacuum.
[SIGPIC][/SIGPIC]Former Membership Chairman Former ZR-1 Registry - BOD 1972 Corvette 4speed base Coupe SOLD long time ago 1984 Corvette Z-51/4+3 SOLD 1992 Corvette ZR-1 Aqua/Gray #474 SOLD 1992 Corvette ZR-1 Black Rose/Cognac #458 2014 Honda VFR Interceptor DX Last edited by XfireZ51; 12-24-2016 at 11:05 AM. |
