Old 04-17-2011   #1
rhipsher
rhipsher's Avatar
Default Water pump replacement.
I finally got some time to pull the water pump off and get ready to put the new one on before the Texas weather turns brutally hot. If any of you have to do this I highly highly recommend that you when you receive your new water pump that you take the gasket that comes with it and make a template out of cardboard and place each bolt you take out in it one at a time so you know where they go when you put them back in. Half of them are all different lengths.
Also don?t forget about the one bolt that goes throught the A/C compressor through to the water pump which means removing the alternator which requires moving the plenum out of the way. Which blows booty hole for just one bolt. But it is what it is. Now im just waiting for my blue Samco radiator hose kit to arrive and finish it up.
Old 04-17-2011   #2
ittlfly
Default Re: Water pump replacement.
Just a little confused here. I didn't quite follow as to why you had to pull the plenum. I R&R'ed my alternator last month without pulling the plenum.....just the air horn and TB.
ittlfly is offline   Reply With Quote
Old 04-17-2011   #3
rhipsher
rhipsher's Avatar
This bolt is why.
I could get a 10mm open end wrench on it from the front but could not break it loose. And there's no room to get a socket or ratchet on it unless you do it from the top. You still have to remove the alternator to get a socket on it. That's why. Sure you can remove the air horn and tb but I chose to just move the plenum aside.
Old 04-17-2011   #4
ittlfly
Thanks for the picture. I wonder just how much they paid their GM enginering wizard to put that bolt in the worst possible location.
Old 04-17-2011   #5
Rick,
You can save yourself a little trouble by putting the bolts in the proper hole in the new water pump on the bench, as you remove them from the old pump on the engine. Then, after the old pump is off, put it on the bench beside the new one & transfer the bolts over to the old pump & reinstall the new pump accordingly.
Jerry :-)
Old 04-17-2011   #6
rhipsher
rhipsher's Avatar
Rick,
Jerry :-)
True that. But see now my daughters think daddy's an awesome free hand artist. The couldn't believe how perfect I drew that gasket sketch.
Old 04-17-2011   #7
USAFPILOT
USAFPILOT's Avatar
you also risk the chance your kids come along and play with the bolts
Old 04-17-2011   #8
rhipsher
rhipsher's Avatar
They are old enough now that they know better.
Old 04-18-2011   #9
bdw18_123
Thanks for posting those two pics of the waterpump bolts, rhipsher! The previous owner of course just mixed them all up on mine. So those pics along with Jerry's bolt info will help me get them sorted out.
Old 04-18-2011   #10
This may help a bit more than the list. I added the quantity & length values.
