Old 04-25-2012   #1
efnfast
Default Back fire at start
Just put headers and exhaust on the car. Now when I start the car in the morning, it backfires? kinda'. Injectors leaking fuel into cylinders? I've only had the car for a year and I don't know if they've ever been changed.
TIA Steve
Old 04-25-2012   #2
VetteMed
Default Re: Back fire at start
I was experiencing backfires on a consistent basis when I had a vacuum leak.
Old 04-25-2012   #3
efnfast
It only does it when I first turn the key, before it really fires up. Seems to be running fine. Altough the idel has been high, and fluctuating. Maybe a vacuum leak, or just 'cause it's breathing better.
Old 04-25-2012   #4
leak in the exhaust at one of the pipe joints will do it too
Old 04-25-2012   #5
VetteMed
High fluctuating idle is another common sign of vacuum leak. How is your cruise control and HVAC working (do all the different vent positions function properly)?
Old 04-25-2012   #6
efnfast
haven't used the cruise lately. HVAC seems to be ok, but I'll pay closer attention. It does this before the engine even fires up. Like one of the cylinders had some fuel sitting in it.
Old 04-25-2012   #7
VetteMed
yes, mine was doing the same thing when I had a vacuum leak at the junction of the check valve and the line that supplies the HVAC and cruise systems with their vacuum.
Old 04-25-2012   #8
efnfast
Sounds like I better start looking for a vacuum leak. I would have thought a vacuum leak would only be a problem after the car was running.
Key on, engine not running- vacuum pump cycled at 1 min, 45 sec's. It only ran for about 2 seconds.
Old 04-25-2012   #9
scottfab
scottfab's Avatar
I get a backfire every time I release the key too early after a start.
Solution: I keep the key turned a little longer.
Scott
Old 04-25-2012   #10
sammy
might ck and see if the hose connected to the sensor at the back of the plenum is tight , it gets oil and heat soaked and can leak .
