#21 |
craig , after the 60 runs i have made on these tires , i have found them to work the best at 23lbswarm. before your first run do a good 5 sec burn out . then every run there after you will only need a 2-3 sec burnout .any longer and the tires get oily. perfect temp according to nitt0 is 190 deg. enjoy . of also a good starting line rpm is 3000 .if you have a fidanza flywheel. do a controlled release of the clutch off the line .
#22 | |
#23 | |
![]() Join Date: May 2010
