Old 01-25-2014   #1
alnukem
Default Questions about Callaway Twin Turbo Drivability????
I hope I didn't violate anything, since this is not ZR-1, but I wanted some input. I am starting to see Callaway Twin Turbos coming into my humble price range. I know there are members that must have had or have these cars. I have never owned or drove a turboed car before & was curious of the driving performance.
1988 RPOB2K Performance
382 BHP @ 4000 RPM
562 Torque @ 2800 RPM
0-60 in 5 seconds
0-100 in 12.4 seconds
1/4 mile in 12.8 to 13.7 depends who you read.
I guess there are some pretty simple & effective performance mods with a low restriction exhaust & a Callaway "Wonderbar" (apparently, a less restrictive frame channel for Air Inlet). Anyway, what's it like to drive one of these cars with, not so much HP & a ton of Torque????? Thanks, Tim
Old 01-25-2014   #2
Default Re: Questions about Callaway Twin Turbo Drivability????
I bought 1987 #17 a few years ago for $13K. It was in rough shape; rebuilt the turbos, all of the lines were leaking, trans leaking. Its a pain in the *** to work on and they are sensitive to changes.
I do not think my experience is typical, but tuning with mods using the Callaway system requires some expertise. I have a prototype intake on mine, I also have the last copy of the sledgehammer cam made by Dave Generous(not installed) along with a wonderbar(not installed).
If you have means, I would say go for it. I would expect to spend a few K on repairs.
They drive like an L98, and power comes on differently than a LT-5....its like something pushes the car from behind
Old 01-25-2014   #3
Old 01-25-2014   #4
Z06scentair
Z06scentair's Avatar
Lookin Good Lee!
Old 01-25-2014   #5
Schrade
How much did resto cost? NOT counting your own time?
Just curious here Mr G; don't disclose if you don't want...
And maybe a little on the frame / airflow tech??? What was the purpose of THAT?
382 BHP @ 4000 RPM
0-60 in 5 seconds
Old 01-25-2014   #6
Its a long way from being done. Come to think of it I might have paid less than $13K, hard to remember. Might have been $11500
Car ran when I got it, drove it from STL to home. It had an oil leak coming from the trans pan, manifold, and turbo sumps. I ported the heads and put in larger valves 2.0/1.55 Manley race valves.
I then found an intake on ebay for $600 (with injectors and rails) that turned out to be a GM prototype that looks close to the 100 plus. It was intended for a Hi-Po 1LE Camaro, but in speaking to Jim McFarland one of the criteria was to clear the Corvette hood. This intake on a NA L98 stock motor would have made over 300hp per mr. McFarland. its one of 4 made! Jim McFarland was shocked it got out of GMs hands, as it was kept quiet. JOhn Hienrecy(sp) confirmed it was a skunkworks project that got scraped because of the upcoming LT-1 project.
I had a lot of experimenting with the fuel rails to get a workable version, and then issues with the fueling. The car runs but boost is a challenge. I am still not sure about the health of the motor. Compression is 115 across all cylinders(its 7.5:1 compression).
So as I left it last year, car ran, although boost was a struggle, it would hit hard after sputtering, etc. I am hoping to finish it in late 2014(have a 368 LT-5 to build and get sold)
Turbo rebuild: $700(I probably could have done this myself after learning about it.
Porting: free
Intake: $600
Misc fuel rails stuff: $300
Sledgehammer cam: $340
Wonder bar: $450
*Car needs new carpeting it sat out in AZ
*Paint is rough
**Keith Martin said this car would never see the road again because of the mech leaks, etc....out to prove him wrong.
Old 01-25-2014   #7
USAZR1
USAZR1's Avatar
Lee,does your TT have a 4+3 or 700R4 trans? What's the engine redline on those engines?
Clint & Sherry
1994 ZR-1 White/Red #152 (sold)
1991 ZR-1 Callaway Aerobody #1332 (sold)
1990 ZR-1 Red/Red #952 (sold)
2002 Z06 Torch Red/Mod Red widebody
USAZR1 is offline   Reply With Quote
Old 01-25-2014   #8
Its the same redline as the stocker because of the TPI.....in the current setup I should be able to run to 6K+. Engine has a better crank/rods/pistons than stock.
Its got the 4+3
Old 01-25-2014   #9
Here is the small wonderbar used from 88-91 on stockers....the big wonder bar enlarges the rail creating a larger plenum:
Old 01-25-2014   #10
Schrade
Do the turbos have any problem getting air through the intake manifold? Any room for improvement there - like porting the intake, or the like???
(L98 intake manifold was designed on flow characteristics of LB9 TPI, and what's why L98 runs out of air @ higher RPM's)
Tags
b2k, callaway, rpob2k
