Old 01-18-2014   #521
JimZRyd
JimZRyd's Avatar
Default Re: MAP Sensor Cover
Received mine yesterday...Very nice! Excellent work!
Jim Zorgias
1994 ZR-1 Admiral Blue/Black #245
1996 Callaway Supernatural 450
1990 Callaway Supernatural 490 / CR-1 #7
JimZRyd is offline   Reply With Quote
Old 01-18-2014   #522
Thanks everyone, have 7 left but will order more soon
Old 03-06-2014   #523
PayPaled.......1990 # 072
Old 03-07-2014   #524
Hey Cliff,
Normally I do 1990 #0072 .....instead of 072
Is that ok?
Old 03-07-2014   #525
Default Initial Maintenance on low mileage ZR-1
Hey Cliff,
Is that ok?
Yep....perfect (1990 #0072)...thanks Lee.
Normally I do a lot of ZR-1/LT5 modifications but on this 90' especially since it is one of the first off the assembly line (and only 38,000 miles)....
No modifications.......Except some Carter Bling and your Map Sensor Cover.......and RC SL4-205 Injectors
Added the Billet Aluminum Belt Tensioner Pulley and did the standard Dynomite Top End Restoration including Starter Solenoid
Remove Plenum and clean Valley drain, fix ALL vacuum leaks including check valve on passenger side under Plenum, block TB Coolant at Injector Housing and often replace Injectors. Requires New Plenum Gasket from Jerry.
Changed ALL fluids.......AMSOIL 10W-40 Engine, CASTROL 10W-60 Transmission,
Mobile 1 75W-90 Differential and some NAPA Green antifreeze
And since changing out Differential Fluid...added the 1/8 inch NPT Allen Drain Plug.
Lee.......installed the 1990 #0072 today.....looks superb as that is the only visible modification to this LT5/ZR-1
The LT5 runs soooooo smooth.......just installed new Clutch Master and Clutch Slave from Jerry.
Also replaced all four speaker amps with 95 Nissan Max amps for a perfect sounding Bose System.
Have South Dakota Plates (UWLNTWN) on the way.
Old 05-24-2014   #526
Need a 1990 #3032
Let me know if you have any left
Old 05-24-2014   #527
randy ransome
randy ransome's Avatar
I'd like one also if you still offer these.
1991 #988
I'll take two if you have enough
1995 #069
Let me know about payment.
Thanks,
Randy
Old 05-24-2014   #528
Let me check I think I have enough, time to reorder....
If anyone else wants one let me know so I know how many to order
Old 05-24-2014   #529
Yes one more
1993 # 179
Steve
1990 Steel Blue/Black #2355
1990 Red/Red #1473
1991 Quasar /Black #118 Sold
1993 Yellow/White #179 Sold
Old 05-24-2014   #530
1993 179
1990 3032
1991 0988
All done ....paypal is leegaffigan@yahoo.com
Thanks
Be sure to send the correct address
I am officially out of MAP sensor covers
