Old 06-04-2015   #1
Racinfan83
Default Help! no start
Drove car to dinner. Started great, ran good. Got out of dinner, turn the key fuel pump runs, dash lights up, no solenoid click and no start. No tools. What do I try first?
Old 06-04-2015   #2
geezer
Default Re: Help stuck in parking lot no start
Since you have fuel pumps working - Are you able to try push start ( 2nd gear)?
geezer is offline   Reply With Quote
Old 06-04-2015   #3
1990 quasar blue
Clutch safety switch? Try pumping the clutch pedal.
1990 ZR1 #2574
Medium Quasar Blue Metallic
1 of 19
Old 06-04-2015   #4
Easy to bypass
http://www.zr1.net/forum/showthread....+switch&page=2
LGAFF is online now   Reply With Quote
Old 06-04-2015   #5
Racinfan83
Some guys from the club pushed me and she pop started right up in 1st gear. Got it home in garage. Now to figure out why the heck it did it....
I pumped clutch hard into stop several times, security light went off when door shut and key on, beats me. Started right up after sitting a couple weeks, drove 5 miles to dinner, in there bout an hour, came out unlocked door with key, key in ignition, turned on, everything worked except nothing when turn key to start. No click no nothing.
Just now shut it off in garage and it started right back up. Twice. Now I'm afraid to drive the damn thing......
Old 06-04-2015   #6
it's probably the clutch switch. there isn't much you can do now other then let it cool down and then jump it out later. Used to happen to mine all the time till I jumped the switch
Old 06-04-2015   #7
Racinfan83
Hey Kevin, since ur a Mod, please edit the title and get rid of the stuck in parking lot part???
Since now it's home..lol
Old 06-04-2015   #8
Default Re: Help! no start
done my friend
Old 06-04-2015   #9
Racinfan83
Thanks. I didn't want people wondering if I was ok.
I guess I have some reading to do now in the solutions section so I can track this down. I may just start with a new battery and go from there... Not sure if I can fit in where the clutch switch is to mess with it.
BUT - just in case - does someone have a part # and or link to where I can get another clutch switch that is better? If I manage to get in there I would probably just change it..
Old 06-04-2015   #10
don't bother changing it, just jumper it out. it's better in the long run. move the seat all the way back take the roof off and get your kids to do it
