05-03-2019 | #11 |
Re: Disabling the Air Bag and Seat Belt Warning Lights
If you have not already seen this post, it might help to answer your question about the air bag:
https://www.corvetteforum.com/forums...ll-96-a-5.html Sent from my iPhone using ZR-1 Net Registry
05-03-2019 | #12 |
Wow this is all great information guys! I have ordered the resistors and should have them tomorrow evening. I’ll take the car apart tonight if I have time and hopefully this addresses both the seat belt light and airbag. One more thing off the list.
05-14-2019 | #13 |
Still trying to get this to work. I purchased a 2w 5ohm resistor and tied it into the original harness as shown.
When I turn the key on I still get the INFL REST light. Does the car have to be running? Not knowing where I am going wrong. IMG_0610.JPGIMG_0609.JPG Sent from my iPhone using ZR-1 Net Registry |
05-15-2019 | #14 | |
05-15-2019 | #15 |
Hello there,
The car is a 1990 and I believe only has the one airbag. The resistor is a 2 ohm 5 watt piece. The only thing I was thinking was with the seatbelt light on as well is that the issue? Any help is appreciated. Thank you, Tony Sent from my iPhone using ZR-1 Net Registry Last edited by Rumblin70SS396; 05-15-2019 at 12:28 PM. |
05-15-2019 | #16 |
https://www.corvetteforum.com/forums...amp-reset.html
Checkout this thread. I think it will help you out. From what I gather your seatbelt sensor may have lost ground. The airbag light might go out after you clean that also. |
05-15-2019 | #17 | |
GOLDCYLON - 91 ZR-1 #2014 GOLDCYLON - 90 ZR-1 #2794, 4L60e (Formerly Schrade's) GOLDCYLON - 11 CTS-V Arizona State Director 91 WHITE/BLACK #2014. 380 P&P&PCed,Ported Heads, Jeal Long tubes, Corsa Exhaust/FIKSE FM-5s /LED TLs, LED Headlights, Front Wilwood 6 piston narrowlite calipers and rear Wilwood caliper street shop mod,CNCed Coolant Pipes,TPI Cvr,Filter cover,Stainless Bolts, DRM/DOM PROM /ZFDOC mod build #102,DRLs,BMAD with stainless Debris Screen,Coplan Air Blaster, Pioneer APP Radio 4,Brey-Krause HB,Sub Bar,Fire extinguisher seat mount,DRM Coilovers,LEDs everywhere,Compass mirror (orange),V1 DIC hidden display, Homelink sun visor, Carbon Fiber top x3 and APSIS Carbon Fiber interior, APSIS CF Steering Wheel/NAPA Leather, Banski trailing arms, Guldstrand front suspension,urethane bushings from Prothane (total suspension) ZFDoc drive shaft safety loop, raptor shift light (orange),AO engineering louver front plate, Console seat cushion, 96CE seats with black custom Sheepskins, ss billet catch can,Viper remote entry/alarm,Cragar Rear Louvers,LED side louver lights, Dewitts Radiator with SPAL fans and a Woods 160 T-Stat 90 RED/BLACK #2794. 4L60e Automatic Stage V by RPM Transmission, TCI Dedicated TCM, OBX Stainless Headers, Corsa Exhaust, SAN Secondaries and Haibeck PROM, Exotic Muscle Coil overs, LED Interior Lights, LED Tail Lights, LED Headlights, 94 Sport seats with black custom Sheepskins , Cragar rear louvers, GS Front calipers, Banski Trailing arms, APSIS Carbon Fiber steering wheel, Front and Rear Baer Eradispeeds, DRLs, Guldstrand front suspension,urethane bushings from Prothane (total suspension), Dewitt's Raditor with Dual SPAL fans and a Haibeck 170 T-Stat 11 RED/GREY CTS-V Last edited by GOLDCYLON; 05-15-2019 at 11:55 PM. |
05-16-2019 | #18 |
Thanks again all! I see where the talk about the sensors grounded to the frame. Are they talking about the seat frame or frame of the car. If the latter, where are the sensors located?
Thank you, Tony Sent from my iPhone using ZR-1 Net Registry |
05-16-2019 | #19 |
frame of car. I think around battery area but don't quote me on that.
05-16-2019 | #20 | |
Also, be sure and clean the wiring connections in the driver's and passenger's footwells. They will be the yellow wires. As a precaution, dis-connect the battery and wait a while before working on the sensors or wiring.
Kenny 1990 #442 |
