03-31-2021 | #13 |
Re: R-12 to R-134 conversion
I don't know about the high pressure switch but the low pressure switch is adjustable by turning a screw between the terminals.
The low pressure cut off is 2 lbs lower for R12 than R134a but the switches are the same. If you buy a new replacement, it will be set for R134a. I'm still running R12 and I discovered this when I had to replace a faulty LPS. |
