04-16-2007 | #1 |
Loose Bolts
Just an FYI I was pulling my plenum and injector housings so I could send them for port and polish and the first 4 outside bolts on both sides of the injector housings were loose. I mean they had zero torque on them. I think this is the first time this engine has been torn down this far. It's a '92.
04-16-2007 | #2 |
Re: Loose Bolts
It happens, I've had a few motors that have been like that. Might cause a small vacuum leak that is hard to track down. They are not torqued down very hard in the first place.
04-16-2007 | #3 | |
Re: Loose Bolts
04-18-2007 | #4 | |
Re: Loose Bolts
12-26-2009 | #5 |
Re: Loose Bolts: IHs as well...
I found my IH bolts in much the same situation - first time I pulled the plenum. One was little more than finger tight! A little BLUE Locktite seems to be doing the trick.
I suspect too that after using LT or other goops one should run a thread chaser thru the bolt hole to clean out the threads of any residue before reinstalling the bolt and torquing it down in the interest of uniform bolt pre-load. (Or, at least I would on an iron head. running a tap thru an aluminum part gives me some pause, how-some-ever.). P.
12-26-2009 | #6 |
Re: Loose Bolts
Yea I noticed the same on my 90 when I had to replace my bad OE injectors. You should have seen how loose the CCVB cover bolts were also. Made a mess of my valley!
W/pump T/Q = 26 N.m or 20 Lb/ft I/H bolts = 26 N.m or 20 lb/ft, my 90 FSM has no pattern diagram. Plenum bolts = 26 N.m or 20 lb/ft, see pattern in FSM T/Body bolts to plenum = 26 N.m CCVB cover bolts = 10 N.m or 89 In/ lbs Tom
