Old 03-04-2010   #1
Default Viton Fuel System O-ring Seals for Ethanol Blends
Jerrys Gaskets has added "Viton"-A o-ring seals to the LT5 product list. Viton-A is the preferred material for modern automotive fuel systems designed to function with ethanol blended gasoline fuel.
Locate "Gaskets & Seals" under the Categories heading on the left side of the home page. Open "Gaskets & Seals" & look through until the fuel seals needed are found. Please note that we do still offer fuel seals in "Buna" for customers using 100% gasoline. Simple read the description for "Viton."
We stock ALL Gaskets & Seals for the ZR-1 LT5 engine.
example: for 1990~92, Primary Injector Lower Seal, "Viton" PN 10067600-V
http://www.jerrysgaskets.com/seal-se...on-90-92-11d8/
Jerry
Old 03-04-2010   #2
billybaloneey
billybaloneey's Avatar
Default Re: Viton Fuel System O-ring Seals for Ethanol Blends
Jerry,
If you have not yet shipped my current order, I'll take a set for my '94.
Email or PM me on how to handle the transaction.
Thanks,
billybaloneey is offline   Reply With Quote
