Old 07-27-2010   #1
HAWAIIZR-1's Avatar
Default My First Attempt at Camshaft Timing the LT5
I was ready to start timing after:
- Installing the camshafts to factory settings and determining TDC
- Getting a degree wheel mounted
- making a metal bar to bolt on magnetic base
- a dial indicator with homemade extension tip
- installing an indicator on the block
I screwed up drilling the hole in the plate and had to end up on top of the camshaft hold down, not ideal. I don't have a drill press and it would have meant going back to the auto craft shop on the post to drill another hole and it worked anyway.
Thanks Pete for the late night call I had to make when I initially got the camshafts and forgot that since I don't have stock camshafts it was not going to line up so easily like the factory manual and CPT video indicated.
I probably should have waited and not installed the front cover, but I did not have the heads or camshafts at that time and wanted to keep moving on this.
After establishing TDC but before installing the heads, I set up the locations on the torsional damper with the timing tab and locked everything down so I would not have to find TDC with the heads on. By the way, the tape was removed from the intake and exhaust ports during the process.
There are many ways to do this; I just threaded some welding rod that I found at the local hardware store with a 4-48 UNF die and cut to length. I was going to do the curve around the camshaft but found I did not need to by catching an area to the immediate side of the camshaft lobe.
It took me awhile learning the process of this, special thanks to information from Marc Haibeck's site to give me the basic idea; more importantly the details from Registry Member Jim Milstead who explained how to make the adjustments once I found the factory setting was 2 degrees off where I wanted to be for the intake cam.
I went round and round to get the feel and figure out the MOP (maximum opening position) and then got it down to where I feel comfortable and the other (3) will go much quicker.
The bottom line, it was not as difficult as I thought it was going to be or maybe I am more capable than I think I am. I can see why shops would charge quite of bit of labor to do this.
I'm not done with the first cam (left intake) even though I have it adjusted and checked/confirmed a few times. I need to wait until I get help to have to back of the camshaft held for my final torque with new bolt and lots of loctite (not too much of course).
Hopefully we can do the final torquing without moving the setting or will be doing it all over again. I did this by myself so it took longer. I know if I had help when making the adjustments it would have been much easier since it does not take much to move the setting once the bolt is loosened and I had to do it more than once to get the right setting and then lock it down with one arm holding the back end and the other tightening the sprocket bolt.
The bottom line, get someone to help you......period. I just did it myself to get used to before having my friend come over and went farther than I had planned to; I was just going to set it up and check where the factory setting were at.
Well, I just thought I would share my novice point of view on my attempt with timing the LT5 camshafts. I'm going learn more about this over the next few days and figure out better ways of doing everything.
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
NCM Lifetime Member #2048
Old 07-27-2010   #2
Default Re: My first attempt at timing the LT5 camshafts
Well, I just thought I would share my novice point of view on my attempt with timing the LT5 camshafts. I'm going learn more about this over the next few days and figure out better ways of doing everthing.
You go dude! Serendipity...a marvelous teacher! And, you'll get the satisfaction of knowing the LT5 pretty well.
Do you have a target date for turning the key???
P.
Old 07-27-2010   #3
HIZNHRZ
The bottom line is it was not as difficult as I thought it was going to be or maybe I am more capable than I think I am.
I think the latter...you don't give yourself enough credit dude. There are guys who work their entire careers around engines and cars who have never been this deep inside an engine much less an LT5. Your car will be back on the road because YOU are making it happen. Once you get the cams set up I have to believe the rest is all down hill. Great job!
Old 07-27-2010   #4
Scrrem
Scrrem's Avatar
Awsome Craig!! Great documentation. Keep'm coming!!
Rich
1990 Bright Red Coupe #608
Coated SW Headers / Corsa
Ron Davis Radiator
Pioneer AVIC-Z140BH NAV
Old 07-27-2010   #5
HAWAIIZR-1's Avatar
P, Scott and Rich,
Thanks for the comments and vote of confidence. It sure is a good feeling to build one of these motors even though there were many times filled with frustration (mostly trying to get the parts and the cost). It is kind of crazy when I think about it but not much choice with the cost and logisitics of shipping it to a builder on the mainland.
I'm not sure when I will be able to turn the key, but my target is before the end of August. I still don't have the plenum, IHs and TB back yet so hopefully that does not hold me up. I would like to drop the motor back in by next week at the latest so we'll see.
I'll keep you folks posted as I make progress.
Aloha,
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
Old 07-27-2010   #6
93 ZR1 Barcelona
93 ZR1 Barcelona's Avatar
I will be doing the same in mine in about two months. Just have finished to clean all parts and will send the block & heads to the machine shop maybe next week.
Were did you get those bridges to clamp the camshafts adjusted to the head bores? Custom made? Or are from the Kent Moore tooling?
Good luck with the assembly, nice job.
Regards,
Ramon.
93 ZR1 Barcelona is offline   Reply With Quote
Old 07-27-2010   #7
HAWAIIZR-1's Avatar
Regards,
Ramon.
Hello Ramon,
Great to hear from Spain and I know you have more challenges than I do with the logistics end.
I bought the camshaft temporary retainers from Bill Kirchoffer here:
http://www.zr1netregistry.com/ZR1_parts.htm
I'm not sure if he is still doing it or not as I tried to call and email some time ago with no reply to get more tools. A set with other items were on Ebay so they come up sometimes but not sure if anyone else is making them. Someone should if Bill K has stopped making them. I can't afford the real deal and all his tools worked fine for my rebuild.
I bought some tools from SPX but a little price; they have these retainers as well as some of the others:
http://gmspecialservicetools.spx.com/
Best wishes on your build too.
Aloha,
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
Old 07-27-2010   #8
GrayZ
Craig....dude....great job!! give yoself some credit bro.
I wouldn't even attempt what you are doin.
cause if'n i did, i have to send my car to Marc or Corey or JVD to fix
my screw up....
You will be proud as punch as soon as you're baby is back on the road.
what's up with retirement and relocation???
GrayZ is offline   Reply With Quote
Old 07-28-2010   #9
HAWAIIZR-1's Avatar
my screw up....
Thanks Keith, as always positive feedback from you and I appreciate it.
I can't wait to get it on the road, especially after you letting me feel what I should expect.
I retired at the end of Nov but going into leave status until then. I will be relocating to where ever that next job is. Right now the only strong thing in the hopper is a governement job here in Hawaii and I interview for it tomorrow afternoon.
Take care and Aloha,
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
Old 07-28-2010   #10
HAWAIIZR-1's Avatar
Okay folks, here is the deal. The camshafts are timed and what an experience! I had the help of James93LT1, a local guy that I met through here and has been helping me with everything that I need an extra body and set of hands and mind for. We started at 2PM an finished at 7PM. He was enjoying all the challenges along the way and we got the hang of it after the first or second one. It was spooky as we got the sequence going and knew what we were doing, but took our time and analyzed along the way.
It is a good thing to have a smart and patient helper. James does not even own a ZR-1, but sure does know alot about them and I could not have asked for a better person to help me out.
What we did find after doing the left (driver's side) camshafts is that the dial indicator extension that I made being just straight was alright and there is enough clearance right next to the lobe to get to the top of the lifter with the right adjustments to the indicator. The right side (passenger) was a little more challenging and I can see why the few pictures and info that is out there shows or indicates making an extension that bends around the camshaft. We were going to fab one up but I did not plan on doing this again anytime soon and just wanted to get 'er done so we drove on and found the sweet spots to use the straight piece of threaded welding rod that I made. I think I will make that rod with the bend for the dial indicator while I have the covers off so if there is a next time, I'll be good to go.
The biggest challenge as they say is the final lock down with Loctite and torque with new camshaft sprocket bolts. Only one moved after final lock down and even though it was only about a 1 1/2 degrees off we did it over and had to use a new bolt and found I put too much Loctite. It was a little panic for me, but James was not sweating it as I could not put the new bolt back in with all the darn Loctite already curing; it was washed out and start all over with success. We found all the camshafts to be about 2-3 degrees off the ideal settings with factory pinning and needed to adjust all of them. All the camshafts were checked for timing again even if it was a little time consuming to remount the dial indicator on all 4, it was worth it to confirm. My second best friend during this was the 3/8" and 1/2" drive Snap On Techangle torque wrenches I bought late last year for this build. Very sweet wrenches and awesome for the angle needed for torquing the sprocket bolts and keeping an eye on the dial indicator; just need to listen for the beep and vibration to know you are there.
It was awesome and a good feeling to get this done right. Thanks James and "BIG MAHALO" for all your help as always. He is going to help me put the LT5 back in and we hope to do it by the weekend.
Well, I guess I can join the "Timed the LT5 Camshafts Club" now.
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
