07-18-2011 | #1 |
Detailing Engine compartment
Okay guys who has the best tool to get into all the crevices of an LT5 engine. Has anyone tried a steam cleaner and boxes of q-tips.
07-18-2011 | #2 |
Re: Detailing Engine compartment
your hand and a rag. anything else and you're going to be replacing the starter
07-19-2011 | #3 |
07-19-2011 | #4 |
i guess you could pull everything apart and pressure wash or steam it but that's just a guess
07-20-2011 | #5 |
I have a commercial hand steamer that I have used for years, Just not on an LT-5 engine. I guess if it burns the finish that will give me a reason to have the Siamese intake done.
07-21-2011 | #6 |
I use a pressure washer. If you stuff wads of plastic bags at the top
of the plenum to diver excess water you'll be fine. Small amounts of water in the V aren't a problem. It's only when you exceed the rate at which the drain hole can handle that you get in trouble. AND of course you need to "blow dry" the compartment out when you're done. I only know of one way to do that PS take the plastic bags out before taking it out for the blow dry run.
07-21-2011 | #7 |
My wife saw me struggling to get in the crevices and tight areas of the engine and bought me a package of wooden shish-ka-bob skewers. They are about a foot long, pointed at one end and blunt at the other. They are fairly soft wood so if you are careful you can clean crevices without damaging anything. You can also wrap a cloth around the skewer and get into medium crevices.
07-21-2011 | #8 |
When I first got my Z I commandeered the wife's clothes steamer to spif up the engine compartment. It worked great for this purpose using distilled water together with windex spay on the extra grimey areas.
07-21-2011 | #9 |
a steamer wil work fine to help loosen the grime up but be ready to wipe it clean & dry. What finish is on the engine? paint? powder coat?
07-23-2011 | #10 |
[QUOTE=RICKYRJ1;119435]a steamer wil work fine to help loosen the grime up but be ready to wipe it clean & dry. What finish is on the engine? paint? powder coat?[/QUOTe
powder coated. I am going to try the steam. If it damages the finish it really doesn't matter as I am going to send the cam covers and intake to DRM for Black powder coating. All of the original engine work was done by DRM it has the same specification and was built the same time all of the Black Widow engines were built. I wonder why the original owner did not get the engine powder coated black at that time. |
