#1 | ||
edit: There are NO problems with the engine, no codes, nothing. There is only the 'off idle sag' / slow response in rpm's. 5V Voltage FROM THE TPS, back to the ECM, is LINEAR; half throttle = approximately 2.3V. TPS resistance, in mine, is exponential / logarithmic, as snappics show here. ========================================== What's the solution to this? Is it common also in '90? And do you mean a SPIKE in resistance; not dip??? edit: ain't no SPIKE in mine; it's just VERY LITTLE CHANGE, as the arm swings to midpoint!!! Then it GOES. See snappics below I give mine SLOW pedal, and rpm's still respond slowly, until it GOES... Exactly which is the lead to test / procedure? Quote:
![]() Join Date: May 2013
Schrade, since the TPS is a potentiometer it has 5 volts and ground from the ecm on the outside leads with the center lead as the signal wire. TPS signal voltage varies from about .54 volt at idle to approx 5 Volts at WOT.
According to the FSM the Blk wire is sensor ground from the ECM, the Dk Blu is the TPS signal, and the GRY wire is the 5 volt reference from the ECM. As you know the resitance should be linear so any spike/dip in Ohms is a problem as the voltage back to the ECM will fluctuate with the resistance. The solution is to replace the TPS as you probably cannot replace the guts of the TPS potentiometer. This is all from my 1990 FSM. Wire colors may be different on later years. Hope this helps. |
Thanks...
Is there a TSB for '90 TPS? Do I need an osscilloscope to test it? Or just a multimeter? |
OK - if the TPS potentiometer response is LINEAR, then there should be a way to rig an arm of a sort, get a range of motion for the arm, then to confirm impedance at 1/4 range, half range, etc.
That is, as long as it is LINEAR... |
Its a sealed unit from what I can see so as to protect it from the enviroment. A voltmeter or Ohm meter can be used to check it. Since it is attached to the throttle shaft then it could be verified off the car with an "arm" to watch the resistance change. Most of the defective ones i've seen are bad just off idle position. The FSM doesn't state that it is linear, that is my assumption. If it was logarithmic then the throttle response would be somewhat erratic I think.
deleted to post #1...
![]() Join Date: Apr 2004
I may be wrong here but I have always tested them on the car with a jumper. they sell a test jumper to hookup so you can watch the voltage as you cycle the throttle.
http://www.ecklerscorvette.com/asset...ette/A8906.pdf http://www.mamotorworks.com/corvette...0test%20jumper You can also watch it on a scan tool if you have one.
Steve 1990 Steel Blue/Black #2355 1990 Red/Red #1473 1991 Quasar /Black #118 Sold 1991 Turquoise/Black #766 Parted Out 1993 Yellow/White #179 Sold 1990 Black/Gray #1361 Headers/4:10s Sold Last edited by We Gone; 07-23-2013 at 03:45 PM. |
#8 | |
Went to Advance to test a new TPS; they didn't have one.
Tested a '90 'K' platform [V8] TPS (new, off the shelf), and got almost identical results. THis calls for some modification to the throttle body / linkage cam pulley... Which is of course, the answer to the : Quote:
#9 |
It appears not to be linear based on your arm positions. Please remember I assumed it may be linear but the FSM doesn't state one way or the other. It just states the voltage will vary with throttle position from .54V to approx 5.0 V WOT. Also, I always use a analog ohm meter to check the ohms from the potentiometer wiper so that I can actually see if there is a dip/spike in the resistance. The problem with digital meters testing pots is that they don't respond fast enough to a very small ohms change and is very dependent on how fast or slow you move the wiper arm. Usually the problem with a defective TPS is a bad spot on the pot just after you go off idle.
I know your TPS is not shorted or open as you would get a code 21 or 22 set. |
#10 |
Schrade, Something else I just read in the driveability and emissions section states that..." voltage should increase at a STEADY rate as throttle is moved toward WOT about 4.6 volts. The ECM has the ability to auto zero the TPS voltage if it between .46 volt and .62 volt. This means that any voltage between .46 and .62 will be determined by the ECM to be 0% throttle". From that statement I gather that the TPS should be linear. Correct?
