05-04-2014 | #1 |
ZF6 Drain/Fill plug torque
What is the proper torque for the drain/fill plugs on the ZF6?
Is there a difference warm vs. cold? Any sealant on the threads? My 90 FSM says 26 ft-lb in one place, and 34 ft-lb in another! My 93 FSM says 26 ft-lb in one plane, and 36 ft-lb in another! Thanks
[B][I]Josh[/I][/B] 1990 ZR-1 #2875 [COLOR="Red"]Red[/COLOR]/Black 4.10s 1993 LT1 6-Speed [COLOR="DarkGreen"]Polo Green[/COLOR]/Beige [B]"A government big enough to give you everything you want, is big enough to take away everything you have."[/B] |
05-04-2014 | #2 |
Re: ZF6 Drain/Fill plug torque
Tight and then a nudge.
05-04-2014 | #3 |
One grunt
[SIGPIC][/SIGPIC]1991 #0663 |
05-04-2014 | #4 |
tite enuf to not come loose!
it isn't load bearing, just a plug. You probably can't get a torque wrench in there anyhow unless you buy the German Hazet socket for that. |
05-04-2014 | #5 |
I use a 17mm Allen wrench
05-04-2014 | #6 |
Thanks guys.
For the fill plug I used a 17mm allen socket with a wrench on the hex (exhaust in the way of using a ratchet). I suppose a crow's foot could be used with a torque wrench this way if you really wanted an exact torque, but like y'all said it's just a fill plug...
05-05-2014 | #7 |
There are several opinions on this but I use a very light coat of Permatex 300 Form A Gasket on both surfaces of mating parts of all assemblies in contact with oil or water (water pump, oil pan and oil filter housing assemblies). I always use a thin coat of Permatex on the oil pan drain plug, transmission plugs, and differential drain plug also. This not only helps seal the plugs but also acts as a thread locker (A little less bolt torque with a good sealant). Tighten just tight enough to NOT LEAK.
Use of thread Lubricants, Loctite and Sealants
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 05-05-2014 at 03:43 AM. |
08-11-2016 | #8 |
https://www.amazon.com/Sunex-3646-8-.../dp/B006JVU1ZI
stubby set, good quality for the price
1990 ZR-1 #1587 1990 ZR-1 #1727 |
08-11-2016 | #9 |
Lots of ways to skin a cat, I recon...
I use Teflon (plumber's) tape on the threads of all (oil drain) plugs - acts as a sealant AND as an anti-seize agent. Torque...IDK the ft#, but tighten (by fingers), and then as Dom says, a little tug on the socket wrench. Never had a leak, never had a plug become seized (so far!). Oh, and thanks, George, for that LINK! (I'm a sucker for having just the right tool for any job.)
Good carz, good food, good friendz = the best of timez! 90 #1202 "FBI" top end ported & relieved Cam timing by "Pete the Greek" Sans secondaries Chip & dyno tuning by Haibeck Automotive SW headers, X-pipe, MF muffs Former Secretary, ZR-1 Net Registry Last edited by Paul Workman; 08-11-2016 at 09:16 AM. |
