![]() Join Date: Aug 2006
Some of you may recall that I started Wilwood conversion in May 2013. I started with the rear to make sure that I can solve the parking brake issue with 4 piston calipers.
![]() Having solved parking brake concern, I was ready to finish the fronts. However, 380 build, started by head gasket failure, shelved the front conversion for awhile. Well, now that 380 mini-stroker project is complete, I revisted the front brake conversion yesterday. These are 14" two pieces rotors with Superlite 6 radial mount calipers. ![]() And with the wheel in place. ![]() Great big thanks to Jim Voter and Nelson. Also, great big thanks to Phil for supplying Fikse 18 inchers that made this conversion possible. Last edited by secondchance; 01-18-2015 at 09:05 AM. |
![]() Join Date: Feb 2011
It look great! How's the drive with those? firm pedal feel? lots of bite?
![]() Join Date: May 2007
Looks good Yun. I enjoyed helping you complete a well thought out modification to your beautiful 1994 ZR-1.
The Wilwood Front Brake kit was a very straight forward installation with high quality parts. Jim |
![]() Join Date: Jan 2010
Yun, nice job!
There's a freight train somewhere out there missing its brakes! Make sure your seatbelt's cinched up when you stomp on that middle pedal... |
Do the rotors affect stock offset?
#9 |
![]() Join Date: Nov 2007
Nice upgrade, Yun. And those calipers look great too!
Scott |
#10 |
Thanks guys! Last piece is to replace the rear w/ Wilwood two piece to match the front. I think I found a hat with correct offset - within 1/8".
