Old 12-11-2015   #1
Default Tools to Carry in the ZR-1
Tools to Carry in the ZR1 behind the Seats.
Bottom Drivers Side.
Volt Meter, Resistance Meter and 1/4 inch Metric Tools..................1/4 Inch Metric Tools with some additional items noted
Second Layer Drivers Side.
Medium Channel Locks, Phillips and Flat Screw Driver, 1/4 Inch Socket Driver with 7mm Socket
(7mm socket used on all the interior Hush Panel and console screws and exterior ECM Chip Cover),
8mm Flex Open End Ratchet
Top Layer Drivers Side.
Fuel Pump Jumper and ALDL Code Reader/Eraser .........................Plug in to ALDL and Hold Any Button then turn key on to
.................................................. .................................................. .Read Associated Codes
ALDL Fault Code Flasher/Eraser
Old 12-11-2015   #2
Default Re: Tools to Carry in the ZR-1
Bottom Passenger Side................................................... ................Bottom Top Box Passenger Side.
25 ft Nylon Tow Rope, Jumper Cables, Quart AMSOIL 10w-40.........Flex Head Ratchet Set (10mm, 12mm, 13mm, 14mm, 15mm)
.................................................. .................................................. ..(14mm Flex Head Ratchet used on Oil Pan Drain Plug)
Second Layer Top Box Passenger Side..........................................Top Layer Top Box Passenger Side.
3/8 inch Socket Wrench with 3/8 to 1/2 inch adapter .................long 3/8 inch drive 3mm, 4mm, 5mm, 6mm, 7mm, 8mm, 10mm
(Belt Tensioner), 3/8 inch drive Torx 40, Short 3/8 inch drive .....Allen for (SS Bolts of TB, Coolant Manifolds, Throttle Cables)
Wobble Extension, Short 3/8 inch drive 6mm Allen
(Cam Covers), Tire Repair Kit, Swivel Spark Plug Socket
Tire Pressure Gauge in the Center Console
Old 12-11-2015   #3
Mystic ZR-1
Mystic ZR-1's Avatar
What? No hammer?
Old 12-11-2015   #4
What? No hammer?
No Hammer............
I have had everything apart more than once so no hammer needed to break anything loose
Did not included the Tow Adapter and Gorilla Lug Wrench which resides beside the Passenger seat
Tow Adapter Stored next to Passenger Seat......................Gorilla Lug Wrench
The Tow Adapter is made to engage the 1-1/4 inch square tubing of the frame support under the front of the ZR-1.
Old 12-11-2015   #5
Jagdpanzer
Jagdpanzer's Avatar
Here is one of my favorites:
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 12-11-2015   #6
Mystic ZR-1
Break stuff loose?
Hammers are used for applying calibrated mechanical agitation....
Old 12-11-2015   #7
Gunny
Gunny's Avatar
If you've ever attended one of Gordon's schools you might have had the opportunity to watch him demonstrate the proper use of a hammer ... I think it was the BFH model.
FWIW, he straightened a slightly bent rim ... didn't seem possible, but it worked
Old 12-11-2015   #8
And if you screw up with the hammer (or the calibrated mechanical agitation) make sure you have the Triple A Card handy like Phil uses.
And.........you can always take the rims you screw up with a hammer and make great Air Hose Reels out of them........You Guys
Merry Christmas guys
Old 12-13-2015   #9
32valvesftw
Merry Christmas to you Cliff, thanks for all you do for the forum.
Old 12-13-2015   #10
Mystic ZR-1
There's nothing on a Corvette that Gordon can't fix!!!
