![]() Join Date: Jul 2007
There is a post on CF as well, but I had some questions regarding the module.
in that other post, someone said the module was used 90-92 and 93-95 did no and it was in the ECM.. since the replacement ECM is the same for all years (although Kurt's website only states 90-94) then couldn't the module be eliminated and the wiring/harness/ PROM be made to work without the Relay module? I am trying to understand the logic, if the 90 has the module, but I use a ECM that can be used in a 93 in my 90 and it works, I would think you could change something to eliminate the relay module if needed. Now I could be all wrong ont he relay module as I am going by what I read in another post..
![]() Join Date: Nov 2006
I heard and thought the same thing
#3 | |
Now THAT makes sense.. it was not eliminated just moved.. LOL
The secondary injector modules were used for all years. However, the 90 model had a seperate knock module that was later integrated with the ECM. When I had a custom harness made for my 94 LT5 to allow it to run in a 65 coupe the company eliminated the modules and used a relay. They said it would work fine. This appears to make sense since the modules seem to be just an on/off switch. The pulse of the secondary injector is still controlled by the primary injector ground circuit though the ECM. I wasnt confident enough to try this route since I thought the general must have used a more expensive module for some reason. I guess when we cant find any then someone will give it a shot!
#5 | |
Who made your harness? Might need to figure out a different ignition system someday also. |
#6 | |
#7 | |
I need to ook at the wiring but I bet it can be done.. depnding on the signal off of the crank sensor
#8 | |
FWIW, the Northstar went from coil packs to coil-on-plug (much more on-plug than the LSx) for the 2000MY. There was no huge power gain from that. |
#9 | |
#10 | |
Anyway, I agree coil on plug (or coil near plug on the LSx motors) is definitely better. But 25hp better on a ~400hp motor? That just seems unlikely to me. |
