Old 08-10-2009   #1
Jeffvette
Default Heater Core. Another fun project
1990 ZR-1, losing coolant, coolant smell inside cabin. Heater core had finally started leaking. This job is sooooooooo much fun. i would rather be pulling the engine out. Does not help that extra wiring has been added all over the place on this car.
Upper dash pad removed.
Mice/mouse problem? Underneath the passenger side of the dash.
Old 08-10-2009   #2
QB93Z
QB93Z's Avatar
Default Re: Heater Core. Another fun project
Dayum!! From those pictures, it looks like you are trying to pull the engine ........from the back.
Old 08-10-2009   #3
phrogs
phrogs's Avatar
That job is such a pain in the ***, but its even more so with all the extra wiring you have there!
whats the dash have like 12 bolts holding it in so you can access that black box that houses the heater core.
I guess those mice like the coolant!
JOHNNY P
Currently own
Old 08-10-2009   #4
Scrrem
Scrrem's Avatar
Holy Crap!!! Ok maybe my plenum pull won't be that bad after all
1990 Bright Red Coupe #608
Coated SW Headers / Corsa
Ron Davis Radiator
Pioneer AVIC-Z140BH NAV
Old 08-10-2009   #5
rhipsher
rhipsher's Avatar
I'm sure your charging him hansomely for that job. I know I would. $$$$ "Cha ching" $$$$$$!
Old 08-10-2009   #6
Jeffvette
I've got to redo some of the wiring that was done previously. I would like to redo some more as some wires were left as exposed with just solder.
Old 08-11-2009   #7
tccrab
tccrab's Avatar
Jeffie:
Glad it's you and not me.
I wouldn't want to open that can of worms.
TomC
"Crabs"
Old 08-11-2009   #8
ZR1Vette
ZR1Vette's Avatar
Lordy... better thee and me. That job is not for the faint of heart. What is all the 'extra wiring' for?
Old 08-11-2009   #9
Holy chit!
My 72's H/C was an easier job than this looks to be, and I thought that job was a royal PIA! I think I'll do without heat if mine ever starts leaking.
Old 08-11-2009   #10
DMark
DMark's Avatar
TAG!
Just because you never know when you'll need this information in the future.
DMark is offline   Reply With Quote
