Old 08-30-2012   #1
Default LSx Coil Conversion
If only Lingenfelter would do the same for us. Take the 9 slot crank signal and convert it to 24 or 58x to run LS coils. Or even if we needed a crank wheel and then integrate to ECM bypassing the need for IM.
http://www.lingenfelter.com/sites/li...ule%20v1.5.pdf
Old 08-30-2012   #2
mike100
Default Re: LSx Coil Conversion
maybe there would be too much interpolation with rapid engine speed changes trying to have an accurate crank angle signal with 9x to 58x.
Old 08-30-2012   #3
Mike,
U could do 9x - 24x instead. BTW, you can avoid the interpolation by using a crank trigger on the balancer instead bypassing the stock reluctor. Perhaps ATI would modify an LT-5 balancer with 24 grooves for timing.
Old 09-03-2012   #4
RHanselman
RHanselman's Avatar
The new Raptor ECM for the LT5 will have LSx CnP capabilities... I hope to have them by November.
Cheers,
Ron
Ron Hanselman
Founding Member #80
CM Lifetime Member #1093
1991 #383 Twin Turbo
1961 White with Red Int
Old 09-03-2012   #5
Cheers,
Ron
will it work nice with the CCM?
Old 09-03-2012   #6
Cheers,
Ron
Ron,
I'll be anxious to see the capabilities and the cost. Keep me posted.
Old 09-03-2012   #7
RHanselman
RHanselman's Avatar
The Mega Squirt guys say they can make it work with our CCM. They seem to think it's no big deal. I guess we'll know for sure by the end of Sep when testing begins.
