Old 02-29-2016   #1
garyhugo
garyhugo's Avatar
Default ZR-1 ultimate tool kit
Where can I find the thread about all the tools you should carry with you. I know I saw it a couple weeks ago but can't locate it now.
Want to be prepared during MR4.
Gary
Gary
90-1572
garyhugo is offline   Reply With Quote
Old 02-29-2016   #2
Default Re: ZR-1 ultimate tool kit
Gary
I am not sure what thread you are thinking about but there are several threads regarding tools. Some even carry spare parts such as an Alternator (I do not carry spare parts).
Tools to Carry in the ZR-1
Old 02-29-2016   #3
garyhugo
garyhugo's Avatar
Dynomite thanks.
Thats the thread I was thinking of.
Where do I get a tow adapter and fuel pump jumper?
I have an origional Gordon Killebrew ALDL code analyzer. Although larger it's a must keep and carry.
Gary
90-1572
Old 02-29-2016   #4
Dynomite thanks.
I make the tow adapter and Jim invented (Daryll had assembled) the Fuel Pump Jumper. Daryll AKA GOLDCYLON.
Lifting and Towing the ZR-1
Old 02-29-2016   #5
MuRCieLaGo
Some people carry spare parts like alternators? Hahahaha oh my god!
Old 02-29-2016   #6
Do not ask who.......you might be surprised
I do recommend TB Coolant Blocked to get back on track
Anyone who really wants to be prepared for some fixing on the road should Block TB Coolant. I can remove a Plenum in less than 10 minutes on the road if I have to and I DO NOT torque the SS Plenum Bolts or put anything on the Plenum Gasket when replacing. There is only relatively light suction and no coolant pressure with TB Coolant blocked. I would say I snug up the SS Bolts with maybe half the torque specified probably around 10 ft-lbs (no torque wrench required).
Old 03-01-2016   #7
With the MR4 looming, THIS IS A VERY APROPOS TOPIC!!
Old 03-01-2016   #8
efnfast
Cliff, somewhere on this forum (as opposed to the other one) you posted up about what you carried and how you packed it. Like Paul said, with MR4 looming... even if he did use that big word that I don't know the meaning of.
Old 03-01-2016   #9
Trouble is on the Registry it takes three posts for the same information
That is double or triple the work posting the same information. There is a reason for my madness
And......then the maintenance if the information changes or updated over time on two different web sites.
(Registry) Tools to Carry in the ZR-1
I just added the Tire Pressure Gauge to the Registry Tools To Carry in the ZR-1
Tire Pressure Gauge in the Center Console
Old 03-01-2016   #10
32valvesftw
I just went back over the list, I noted that there is a tire plug kit noted (probably the roadside tool I have used the most in recent years), I did not see anything to inflate the tire. I do carry one of those 12V compressors, but they are bulky. Any other ideas for filling a flat tire once its repaired, fix a flat I do not think is kind to the TPMS, it would take about of those little 10 CO2 canisters me thinks, so that's a no-go.
