Old 01-24-2007   #1
Terry Callihan
Default coolant part needed
I have a minor coolant leak,the piece i need is a 90 degree elbow that hooks to a hose right off the air plenum.the hose looks to be in good shape,but the 90 turns and won't tighten down into the plenum.
Terry Callihan is offline   Reply With Quote
Old 01-24-2007   #2
65ZR1
Default Re: coolant part needed
I may be wrong on this, but I thought the tubes were pressed in with a bit of sealant. If the tube is still good then pop it out, clean it and put it back with a bit of sealant. Im not sure what sealant the factory used. Hopefully someone can verify. Good lucK!
65ZR1 is offline   Reply With Quote
Old 01-24-2007   #3
Jeffvette
Crush fitting. Pull it out, use a little JB weld on it or some kind of epoxy and hope it doesn't blow out at 7,200 RPM.
BTW, the pipe is discontinued.
