#1 | |
![]() Join Date: Jul 2007
I found this info from you in another post while doing a search:
It is a nice clean setup. Are the Stainless work headers the first style before they retooled them a year or so ago?
Jeff,
Thanks for the complement. The flex sections provide just enough give on alignment to make mounting and dismounting of the entire exhaust system a snap compared to a rigid system. I'm not sure which style the SW headers are. They fit with no issues and the workmanship was superb. However, wished I'd ordered an extra set of o2 bungs welded in before they were coated. Phil |
#3 | |
![]() Join Date: Feb 2009
That's a great looking exhaust system ![]() Rich
![]() Join Date: Jan 2007
Wide open throttle is ok. When I am cruising along and give it a little gas it sounds like put, put put. Maybe it is just inside that it sounds like crap.
Thanks Phil.. looking to do something similar when I add cats to my current system.. I have Watson's which are the same as the early Stainlessworks ones
I need to get under the car to see what I am needing
I'm running SW's, no cats and Corsa exaust and I can tell you the SW's and the Corsa system don't like each other. In your opinion what can be done to make the sound more likable. The Corsa before the headers sounded great and now other than full throttle it sounds like s***. Would an X pipe improve things?
if i can ask what dont you like about the sound ???? i have the same set up on my 92 and really didnt notice much difference except it was a little louder when you opened it up
Those magnaflow cats are 3"OD on both ends right?
#10 |
