Old 02-22-2014   #1
ZRXMAX
ZRXMAX's Avatar
Default Stainless Works headers
I am installing SW headers on a 90 Z and the pass side header has a 1/2 inch male quick connect air fitting welded on #2 cylinder. Whats that for ?
Also... do I need to lift the motor a little to change the oil pan gasket?
If so...one side or both?
91 ZR-1 #661 Watsons, 3" exhaust, Borlas... Hurst, 4.11s, Samco, RD radiator, gel coated motor... turquise / black
ZRXMAX is offline   Reply With Quote
Old 02-22-2014   #2
Default Removing Oil Pan Engine In Car
Ted.........I think that is EGR (Exhaust Gas Recirculation) which you do not have on 90'......just plug it.
Lift the front of engine a bit (remove two motor mount nuts) to get those three (90') or four (93'-95') front 6mm oil pan bolts out.
Some remove the cross boxes.
Engine lifted in front with 2x4 wood spacer in place.
Oil Pans and Gaskets Differences TIPS
Installing New Oil Pan Gasket
New Oil Pan Gasket and Bolts
Oil pan gasket
Old 02-22-2014   #3
Jitse
Default Re: Stainless Works headers
Installing on Ã* friends Z, sw headers and B&B exhaust.
Made with M10 thread on the inside and screwed in a stainless bolt.
At Jerrysgaskets.com you can find a good installation guide for the oil pan gasket.
Or just follow the links from Dynomite , I use them quite often too.
Jitse is offline   Reply With Quote
Old 02-22-2014   #4
ZRXMAX
ZRXMAX's Avatar
Talking Re: Stainless Works headers
Thanks...
