Old 10-25-2013   #21
Default Re: NPP exhaust valves on my SW 3" pipe set
The system here in FBI land is using the DynoMax Utlraflow. These are straight thru w either tube. I didn't ask about Mike's positioning because of performance.
Rather it was for fit. Perhaps the SW muffs allow positioning on the inside. The DynoMax really have a better fit with the valve on the outside.
Al or Pete could offer better insight on this.
Yeah I think the SW might be side specif due to the inlet maybe? I like how he did it, the Valves are tucked up out of the way..
Either way works...
GC,
I see no reason to add these to Corsa unless you are swapping out the Corsa mufflers
(I am probably one of the only FBI guys running Corsa's) and one of the last who has not ported anything either
Old 10-25-2013   #22
Yes, remember the valve effectively eliminates the need for a resonator. I'm running just an SW Xpipe(unbaffled) with the muff and valves. Reduces weight, cost and restriction.
Old 10-25-2013   #23
Question
Could you add the npp and the mild to wild switch?
With mild to wild you can press a button to open and close
the exhaust
Possible?
Thanks
Old 10-25-2013   #24
Either way works...
GC,
Ok Im still running em but have ported everything.
Old 10-25-2013   #25
Ok Im still running em but have ported everything. Are not the Corsas only one strraight threw I remember a tennis ball demo over at corvette forum. The other pipe is stricky decorative?
Pretty much yes decorative as far as I know.
if you had a pair with dual outputs then the flapper would come into play
Old 10-25-2013   #26
Originally Posted by ZZZZZR1 View Post
Question
the exhaust
Possible?
Thanks
it all depends on how it is set-up on the C6 vs our modded set-up.. if done the same way then it is easy.. if it is not it may take a small bit of figuring it out to get it working
Old 10-25-2013   #27
BigJohn
BigJohn's Avatar
Have you ever heard Callaway Megaphones!!!
Old 10-25-2013   #28
mike100
You are correct. The single outlet acoustical trick along with Corsa's cleverly designed resonator reduces/eliminates drone, but they are still loud from outside the car, decibel-wise.
I remember when I traded a B&B for the Corsa- much more driveable, but still pretty loud from outside the car. Then I went stock for awhile (sans resonator), but missed the extra power and went with the group buy on the SW stuff (but back to obnoxiously loud). This way with the valves is basically having my cake and eating it too.
Old 10-25-2013   #29
I remember somebody cutting one of these open the other side is a backpressure plug but it certainly does not flow like the straight through
Old 10-25-2013   #30
Mystic ZR-1
Mystic ZR-1's Avatar
Yep!
