Hi,
I am entered in my first hillclimb on Sunday, can anybody tell me if my 1990 ZR1 has a rev limiter ? Regards Pat in England |
![]() Join Date: Nov 2007
Yes. IIRC, the stock 90 imiter is approx 7100 rpm.
However, due to the normal lag in the analog tach movement, you may experience the affect of the limiter before the tach reads 7000+ rpm, especially at WOT in the low(er) gears. |
Many Thanks for your response !! Impressive !
Excuse my ignorance what is WOT ? |
If you have the stock chip you should be able to see the shift light that tells you when to shift
Do not keep it over 6200 for a period of time, water pump cavitation
#9 | |
Good luck, Pat!
