Old 04-24-2011   #21
zr1man@yahoo.ca
Default Re: car pulsates under load when in power mode
Originally Posted by Mahogaraunch View Post
I have the exact problem with mine! I have a 1990 ZR1 with 11,000km on it which was recently brought up from Florida. Needless to say, I got it out on the road after a long Ontario winter to find under the normal load the car drives perfectly. Under full power, the car shudders and there is no performance difference.
I have it going in this Monday for service, but I am not confident my garage has worked on a ZR1 before. What does anyone think the repair price for the injectors may run me? Does anyone have reservations about bringing a ZR1 to any garage? I am near the Peterborough area and am unaware of Corvette service shops in the area.
Thanks for the input.
Ive got a guy here in Bancroft (1hr away from Peterborough) that I trust to work on my ZR1 and going to use to help me re and re the plenum and install the injectors and coils. He is a perfectionist but not familiar with the lt-5. I think between this website for guidance and trouble shooting, and a skilled perfectionist like himself that I can use to help me do the install, we should be fine. Ill let you know how we make out with mine and if you want I can give you his number....he could come to Peterborough and give you a hand in your garage.
Also, in my travels i noted a Corvette specialty garage on the 401 somewhere between Oakville and cambridge...not sure where exactly but it was called Grand Sport Corvettes. Might be worth giving them a call and asking if they do service on lt5's.
zr1man@yahoo.ca is offline   Reply With Quote
Old 04-25-2011   #22
batchman
Just to chime in and suggest starting with something easy. I didn't believe it could be this simple, but someone here insisted and they were absolutely right.
Tighten the battery connections.
Worth a shot. You will need the other stuff anyway, but it seems the 2ndary fuel pump and injectors are a significant electrical hit and these side terminal batteries are marginal at best.
Best of luck,
- Jeff
Old 05-03-2011   #23
Mahogaraunch
I noticed when you quoted the part # from Summit for the secondaries, that the part appeared to be primaries only. I called Summit and the only secondaries they stated they had were for $180 per injector. Not sure if this part you quoted would work as secondaries?
Sorry guys, im not a handy tech guy like you all seem, and doing this job myself is out of my league by a long stretch. The references to Ohm's do confuse me. I have a good rapport with my garage in town but they have not worked on an LT5 before. I'm really not sure where to turn next as I brought the car to the garage and had the fuel filter replaced, the throttle body cleaned, and some injector cleaner placed in the tank. They thought if I drove it for a bit it would correct the problem. I took it out for a drive but as the weather has been crap have not had an opportunity to really drive it. I can hear the vaccuum pump running for several seconds when I turn the key to the accessory position, so that would not appear to be the problem.
Not sure if I want to invest $1400 for a set of 8 secondaries plus however long it takes the garage to install it without knowing for sure thats my problem with the car. With everything I read on this board I am confident the secondaries are my problem, but just not 100% sure.
Thanks for any input you guys have.
Mahogaraunch is offline   Reply With Quote
Old 05-03-2011   #24
jrd1990zr1
jrd1990zr1's Avatar
I had similar problems with both my 1990s. Was bad secondary injectors caused by the E10 in gas.
FWIW, I bought a set of 16 injectors from Jon Banner (Fuel Injector Connection) for under $400. http://fuelinjectorconnection.com/shop/
http://www.corvetteinjectors.com/sho....php?groupid=3
Replaced them myself. I am definately not a tech guy. This was the first time I ever tried to do a repair such as this. If you use the instructions here on the registry and have a new set of primary o-rings and a spare set of plenum gaskets from Jerry's gaskets the job isn't that difficult. http://jerrysgaskets.com/store2/root/
Just make sure to drain the coolant down enough and use the procedure to refill coolant. This is probabily the most difficult part.
1968 convertible Lemans Blue,
1986 coupe Medium Blue NCRS Top Flight (sold),
1990 ZR1 #2529 Red NCRS Regional and National Top Flight (sold),
1990 ZR1 #2124 Charcoal Metallic NCRS Top Flight 2010 & 2018,
2003 Anniversary Red Convertible (sold)
Old 05-03-2011   #25
Awhile back, I started making up gasket & seal kits for the most commonly done procedures, in response to many emails asking "What all do I need?". Here's a link for the Fuel Injector Maintenance Kits, 90~92. The only choice you need to make, pertains to which type of seals you want.
Basically, Buna-N is best for 100% gasoline and also happens to be the least expensive. Viton is the best for Ethanol/Gasoline blends, but is more expensive.
90~92 Buna-N kit
http://jerrysgaskets.com/store2/root...roducts_id=458
90~92 Viton kit
http://jerrysgaskets.com/store2/root...roducts_id=459
Please note that virtually all new injectors come with o-rings installed already. That particular o-ring seal is PN1712222. If you are using new injectors, save some $'s, refer to the kit contents list on the website & get everything separately, except the 17112222 o-ring seals.
Old 05-03-2011   #26
zr1man@yahoo.ca
now you have me wondering if i bought the right injectors from summit racing? i got the part number from this reference by a zr1 specialist.
http://www.zr1specialist.com/HAT%20W...eplacement.pdf
he states that accel 150821 is a dirrect fit for the 91 zr1 and he uses this brand often on customers vehicles.
Can anybody confirm if purchased the right injectors for my secondary injectors? acc-150821 8-pack 21 lb/hr $300 from summit.
Old 05-03-2011   #27
lbszr
lbszr's Avatar
I don't know which ones those are, but 150121 $40 each from summit 21# is what I used for prim. and sec. 8 Of them need a plastic tab removed so the electical connector will plug in, forget whether it was sec. or pri.
I would have to look, but I thought mine were yellow though.
Old 05-03-2011   #28
lbszr
lbszr's Avatar
That website is as good as the factory maintance manual. Looks like the same as 150121, only packaged with 8 and saves a little money.
Old 05-03-2011   #29
Mahogaraunch
Well, just ordered a set of 16 from Corvetteinjectors and the gasket set from jerry'sgaskets..
Anything else I need that anyone can think of? Spoke to my shop and they quoted about 3.5 hours to do the job.
Thanks.
Old 05-16-2011   #30
zr1man@yahoo.ca
just installed the parts i had mentioned before...secondary injectors and coil packs and it fixed the car! thanks guys for all the help and now i can enjoy the extra 200hp
