#1 | |
I have it going in this Monday for service, but I am not confident my garage has worked on a ZR1 before. What does anyone think the repair price for the injectors may run me? Does anyone have reservations about bringing a ZR1 to any garage? I am near the Peterborough area and am unaware of Corvette service shops in the area. Thanks for the input. |
#2 | |
![]() Join Date: Feb 2009
#3 | |
![]() Join Date: Dec 2005
FWIW, I wouldn't trust any non-GM dealer with a 1990 ZR1 (except the few specialists discussed by registry members). Likewise, there are very few GM dealers I would trust. I recommend you check the injectors when the engine is hot to verify low resistance. Do the work yourself, there are a number of resources in the technical section. Good luck ![]()
1968 convertible Lemans Blue, 1986 coupe Medium Blue NCRS Top Flight (sold), 1990 ZR1 #2529 Red NCRS Regional and National Top Flight (sold), 1990 ZR1 #2124 Charcoal Metallic NCRS Top Flight 2010 & 2018, 2003 Anniversary Red Convertible (sold) |
#4 | |
Also, in my travels i noted a Corvette specialty garage on the 401 somewhere between Oakville and cambridge...not sure where exactly but it was called Grand Sport Corvettes. Might be worth giving them a call and asking if they do service on lt5's. |
#5 | |
Sorry guys, im not a handy tech guy like you all seem, and doing this job myself is out of my league by a long stretch. The references to Ohm's do confuse me. I have a good rapport with my garage in town but they have not worked on an LT5 before. I'm really not sure where to turn next as I brought the car to the garage and had the fuel filter replaced, the throttle body cleaned, and some injector cleaner placed in the tank. They thought if I drove it for a bit it would correct the problem. I took it out for a drive but as the weather has been crap have not had an opportunity to really drive it. I can hear the vaccuum pump running for several seconds when I turn the key to the accessory position, so that would not appear to be the problem. Not sure if I want to invest $1400 for a set of 8 secondaries plus however long it takes the garage to install it without knowing for sure thats my problem with the car. With everything I read on this board I am confident the secondaries are my problem, but just not 100% sure. Thanks for any input you guys have. |
#6 | |
FWIW, I bought a set of 16 injectors from Jon Banner (Fuel Injector Connection) for under $400. http://fuelinjectorconnection.com/shop/ http://www.corvetteinjectors.com/sho....php?groupid=3 Replaced them myself. I am definately not a tech guy. This was the first time I ever tried to do a repair such as this. If you use the instructions here on the registry and have a new set of primary o-rings and a spare set of plenum gaskets from Jerry's gaskets the job isn't that difficult. http://jerrysgaskets.com/store2/root/ Just make sure to drain the coolant down enough and use the procedure to refill coolant. This is probabily the most difficult part. ![]()
#7 | |
now you have me wondering if i bought the right injectors from summit racing? i got the part number from this reference by a zr1 specialist. http://www.zr1specialist.com/HAT%20W...eplacement.pdf he states that accel 150821 is a dirrect fit for the 91 zr1 and he uses this brand often on customers vehicles. Can anybody confirm if purchased the right injectors for my secondary injectors? acc-150821 8-pack 21 lb/hr $300 from summit. |
#8 | |
![]() Join Date: Nov 2006
Well, just ordered a set of 16 from Corvetteinjectors and the gasket set from jerry'sgaskets..
Anything else I need that anyone can think of? Spoke to my shop and they quoted about 3.5 hours to do the job. Thanks. |
#10 | |
I would have to look, but I thought mine were yellow though. |
