Old 05-01-2012   #21
Default Re: Engine won't turn over when warm
Question: Do you know whether or not the previous owner turned the key and then pressed the clutch, or visa-versa (like should be done to avoid arching at the contact points)?
P.
No idea Paul that was like 7 years ago. But he had to get the car towed three times back to GM. One can assume he was capabile of driving it and starting it. Each time they replaced the switch. He finally got tired of being stranded by it and bypassed it.
Old 05-01-2012   #22
This car comes with a "start defeat" safety switch. There is no other purpose for it.
Other than to piss off the owner when its fails I disagree there is no there is no good reason for it.
I'm not convinced a good lawyer could not make a good case for negligence in a wrongful death suite.
A hollow arugment... any good lawyer can argue anything. My case in point the woman who burned their laps when they dropped hot coffee on it served by McDonald. But Hell I degress
And since we've discussed it on this forum there is a paper trail to at least those involved in the thread.
Beware Lawyer spybots ?
Chances for someone getting hurt? Probably low.
Concur
Chances for a suit happening in this economy if something does happen? I'd say fair.
See my McDonalds comment anything is possible
I for one am leaving my clutch switch in place.
Well ok then
I suggest anyone new to the car do the same.
Well Ok then again
There is no way I want someone later saying I recommended removing it.
Go Boldly
Old 05-01-2012   #23
Brad Sewell
Back to the OP: this was the most useful information I found when I was chasing my no-start. Good luck.
http://www.zr1netregistry.com/ZR1_tr...ting.htm#Start
Brad Sewell is offline   Reply With Quote
Old 05-01-2012   #24
I'd say fair.
on the off chance that someone other them me gets into my car with my car in gear, hits the key, and the car jumps a few feet forward and kills someone, I'm fairly sure I can find a good lawyer to fight that case. I suggest anyone new to these cars disable the clutch switch. There I said it. It's not like the car will fire up and go roaring around town at twice the speed of light if someone happens to hit the key while the car is in gear with the clutch switch bypassed and the clutch out, it's going to lurch forward and die. With the car in neutral and you hit the key, the car is going to start and sit there.
Old 05-01-2012   #25
rhipsher
rhipsher's Avatar
Concur
Well ok then
Well Ok then again
Go Boldly
Im scared now. I'd better put mine back on immediately.
Old 05-01-2012   #26
This is NOT a Clutch Switch Bypass but rather a method to reduce current in the purple wire that may pass through the Clutch Switch. You can also bypass the clutch switch with installation of the Relay if you want.
Starter Relay Modified
Note: I wired the relay a bit different as follows.....
Pin #30: Purple wire to starter (3/8 inch connector).
Pin #87: Red wire battery positive 12v 3/8 inch connector (connected to battery positive multiple connection post).
With this wiring method, Pin #87a is Not hot at any time and not used. (Look at the schematic printed on top of the Relay).
Thanks for clarifying the bypass Cliff
Old 05-01-2012   #27
John Boothby
John Boothby's Avatar
99% of all the manual cars Ive driven if you try to start the car in gear the car will lurch forward. There is no liability issue... Just a mechanic who has no business working on your car. If you start any manual car it could be in netual with your foot on the brake for safety. You can have the clutch enganged or not its a matter of choice. I perfer to have my clutch depressed with the car in netural because thats how I learn to drive a standard. The clutch is always depressed unless you are planning on moving or remaining in neutral
Equating an Airbag to a clutch switch when one of the pair strands your car is simply not worth the debate. Your mileage may vary
The mechanic will not touch the car again. He was recommended by another (non ZR-1) corvette owner.
Old 05-01-2012   #28
VetteMed
I'm proud to say my clutch switch is bypassed. TO hell with the lawyers, and those who fear them.
Old 05-01-2012   #29
hey, I can be happy or right...
(i'm married to a lawyer)
Old 05-02-2012   #30
scottfab
scottfab's Avatar
Don't know that it was put there to piss us off. I personally have never had a problem with the switch but then early on in 97 I understood the problem and began to fully depress and engage the clutch switch before starting the engine to avoid damaging the switch.
Agreed. Someone actually sued the large company I worked for about a decade ago for not explicitly saying in the manual that you could not dry your cat in their microwave. True story. And yet a "good lawyer" would get a large settlement if negligence can be proven to a jury. In this case they lost.
????? They do find stuff on discovery. Depending on which side of a suit you're on this can be a good thing or bad. They just love it when a trail of behavior can be found. It can prove forethought and intentional indifference which cranks up the punitive damage $.
I don't fear lawyers. I fear being stupid. As defined "ignorance" is not knowing something. Stupidity is knowing and still doing the wrong thing.
WITNESS: your honor I resent this line of questioning. The attorney is trying to make me say that I saw the defendant rob the store. He couldn't have robbed the store. I did. ooops
(edited later - I am referring to no one but myself. I did a similar thing to the above once)
I am not a lawyer or married to one but I do keep my mind open when my lawyer friends have spoken. At least enough to know what to do should I hit a pedestrian or how to leave a plausible deniability statement in my prose. (I do this thing XYZ but I do not advocate it for anyone).
It would be interesting to post a "poll" on this as to how many member have bypassed the switch. Maybe there are a "lot" of them. Maybe not.
Scott
