#11 |
My cars pervious owner bypassed the switch because he was tired of having been towed to GM and the switch was replaced three times. He said the problem also occured after driving the car for a while. He would stop somewhere and then no start when he would get into to start driving it again. Always when the car was hot. Very simular to the OPs problem.
A large percentage of us have already done this becuase the switch is a POS. I am glad to hear a few members here have not had a problem. My arugment is its only a matter of time as it will happen at the most inconvient time in the most inconvient place and you be saying damn GC warned me. Im sure age of the componet, mileage and AZZ time in the cockpit all factor in here as to why the switch fails. Or you can just bypass it and when you car doesnt start you know what you can rule out. A no brainer if I ever saw one.
GOLDCYLON - 91 ZR-1 #2014 GOLDCYLON - 90 ZR-1 #2794, 4L60e (Formerly Schrade's) GOLDCYLON - 11 CTS-V Arizona State Director ![]() 91 WHITE/BLACK #2014. 380 P&P&PCed,Ported Heads, Jeal Long tubes, Corsa Exhaust/FIKSE FM-5s /LED TLs, LED Headlights, Front Wilwood 6 piston narrowlite calipers and rear Wilwood caliper street shop mod,CNCed Coolant Pipes,TPI Cvr,Filter cover,Stainless Bolts, DRM/DOM PROM /ZFDOC mod build #102,DRLs,BMAD with stainless Debris Screen,Coplan Air Blaster, Pioneer APP Radio 4,Brey-Krause HB,Sub Bar,Fire extinguisher seat mount,DRM Coilovers,LEDs everywhere,Compass mirror (orange),V1 DIC hidden display, Homelink sun visor, Carbon Fiber top x3 and APSIS Carbon Fiber interior, APSIS CF Steering Wheel/NAPA Leather, Banski trailing arms, Guldstrand front suspension,urethane bushings from Prothane (total suspension) ZFDoc drive shaft safety loop, raptor shift light (orange),AO engineering louver front plate, Console seat cushion, 96CE seats with black custom Sheepskins, ss billet catch can,Viper remote entry/alarm,Cragar Rear Louvers,LED side louver lights, Dewitts Radiator with SPAL fans and a Woods 160 T-Stat 90 RED/BLACK #2794. 4L60e Automatic Stage V by RPM Transmission, TCI Dedicated TCM, OBX Stainless Headers, Corsa Exhaust, SAN Secondaries and Haibeck PROM, Exotic Muscle Coil overs, LED Interior Lights, LED Tail Lights, LED Headlights, 94 Sport seats with black custom Sheepskins , Cragar rear louvers, GS Front calipers, Banski Trailing arms, APSIS Carbon Fiber steering wheel, Front and Rear Baer Eradispeeds, DRLs, Guldstrand front suspension,urethane bushings from Prothane (total suspension), Dewitt's Raditor with Dual SPAL fans and a Haibeck 170 T-Stat 11 RED/GREY CTS-V Last edited by GOLDCYLON; 05-01-2012 at 10:46 AM. |
#12 |
![]() Join Date: Jul 2005
This may sound stupid, but this is what happened to me. I have only heard guys complaining that the car will not start with a bad switch. My car starts all the time, however, the last time I took it in for an oil change the mechanic turned the key over with the car IN GEAR without depressing the clutch and the car lurched forward. He said I had a bad safety switch. I always start the car in neutral and depress the clutch. I assume the switch is to prevent the car from starting in gear. Mine still starts even in gear if you depress the clutch or not. So, do I have a bad switch? Like I said, stupid question.
#13 | |
![]() Join Date: Jan 2009
Sounds like someone bypassed that safety device. Hard to know who would be liable if someone got hurt when the mechanic turned the key. Another reason to leave safety equipment in place and functioning. As for me, I leave air bags working and the clutch switch alone.
#14 |
99% of all the manual cars Ive driven if you try to start the car in gear the car will lurch forward. There is no liability issue... Just a mechanic who has no business working on your car. If you start any manual car it could be in netual with your foot on the brake for safety. You can have the clutch enganged or not its a matter of choice. I perfer to have my clutch depressed with the car in netural because thats how I learn to drive a standard. The clutch is always depressed unless you are planning on moving or remaining in neutral
Equating an Airbag to a clutch switch when one of the pair strands your car is simply not worth the debate. Your mileage may vary
GOLDCYLON - 91 ZR-1 #2014 GOLDCYLON - 90 ZR-1 #2794, 4L60e (Formerly Schrade's) GOLDCYLON - 11 CTS-V Arizona State Director ![]() 91 WHITE/BLACK #2014. 380 P&P&PCed,Ported Heads, Jeal Long tubes, Corsa Exhaust/FIKSE FM-5s /LED TLs, LED Headlights, Front Wilwood 6 piston narrowlite calipers and rear Wilwood caliper street shop mod,CNCed Coolant Pipes,TPI Cvr,Filter cover,Stainless Bolts, DRM/DOM PROM /ZFDOC mod build #102,DRLs,BMAD with stainless Debris Screen,Coplan Air Blaster, Pioneer APP Radio 4,Brey-Krause HB,Sub Bar,Fire extinguisher seat mount,DRM Coilovers,LEDs everywhere,Compass mirror (orange),V1 DIC hidden display, Homelink sun visor, Carbon Fiber top x3 and APSIS Carbon Fiber interior, APSIS CF Steering Wheel/NAPA Leather, Banski trailing arms, Guldstrand front suspension,urethane bushings from Prothane (total suspension) ZFDoc drive shaft safety loop, raptor shift light (orange),AO engineering louver front plate, Console seat cushion, 96CE seats with black custom Sheepskins, ss billet catch can,Viper remote entry/alarm,Cragar Rear Louvers,LED side louver lights, Dewitts Radiator with SPAL fans and a Woods 160 T-Stat 90 RED/BLACK #2794. 4L60e Automatic Stage V by RPM Transmission, TCI Dedicated TCM, OBX Stainless Headers, Corsa Exhaust, SAN Secondaries and Haibeck PROM, Exotic Muscle Coil overs, LED Interior Lights, LED Tail Lights, LED Headlights, 94 Sport seats with black custom Sheepskins , Cragar rear louvers, GS Front calipers, Banski Trailing arms, APSIS Carbon Fiber steering wheel, Front and Rear Baer Eradispeeds, DRLs, Guldstrand front suspension,urethane bushings from Prothane (total suspension), Dewitt's Raditor with Dual SPAL fans and a Haibeck 170 T-Stat 11 RED/GREY CTS-V Last edited by GOLDCYLON; 05-01-2012 at 01:25 PM. |
#15 |
i don't see the clutch switch as a safety issue.
#16 |
#17 |
This car comes with a "start defeat" safety switch.
There is no other purpose for it. I'm not convinced a good lawyer could not make a good case for negligence in a wrongful death suite. And since we've discussed it on this forum there is a paper trail to at least those involved in the thread. Chances for someone getting hurt? Probably low. Chances for a suit happening in this economy if something does happen? I'd say fair. I for one am leaving my clutch switch in place. I suggest anyone new to the car do the same. There is no way I want someone later saying I recommended removing it.
#18 | |
![]() Join Date: Nov 2007
P. |
#19 |
![]() ![]() Join Date: Feb 2010
Someone educate me, please.
When factory new, with the switch in place, should the car require the clutch pedal to be depressed before the starter will even turn? My starter will turn without the clutch pedal being depressed and I assumed that the switch had been by-passed.
#20 | |||
Back to the OPs question: All this said, I DON'T think it is the interlock switch anyway. I agree w/ scottfab. I suspect a connection issue (either internal to the starter or at the battery terminals or ground terminal). If it were the interlock, connecting jumper cables to the battery wouldn't result in it starting. That said, electrical problems often will only show up when devices get hot. So, a cold starter might test OK, but after being heat soaked, things might turn up that weren't there before! P. |
