Old 10-17-2012   #41
Default Re: Who's Modding this winter?
Daryl,what temp would that be if/when the check guages light comes on?
Pete
When it hits the Hashed zone. Followed by the AC immediately kicking off. This happened to me years ago when I was having radiator/water pump issues
Old 10-18-2012   #42
Pete
Pete's Avatar
Thanks
Wow,i just checked the chip programming and it's showing A/C Disable coolant temp 123.50 celsius or 255*fahrenheit.
Pete
'91 #1635 PoloGreen 350 LT5
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 10-18-2012   #43
Paul upgrade to Samcos and get those Samco stainless clamps. Get rid of those Dorman style ring clamps. Did the check Guages light come on? GC
Well... looks like I DO have a winter mod project after all!!
P.
Old 10-18-2012   #44
Thanks
Pete
Yeah it isnt pretty
Old 10-18-2012   #45
Thanks
Pete
Mine got to maybe a 1/8" away from the hashed section. Got there once before (at Bloomington Gold last summer when sencondary fan motor quit), and all seemed well, in spite of it. (I haven't done a compression check, but it ran really well at the dragstrip, so I'm assuming it is OK. But, it does seem to use a quart of oil in about 2000 miles; a little more than before. I'll do a compression check Saturday to see if there is anything to be concerned about... F'n spring clamps!!
P.
Old 10-18-2012   #46
P.
How many miles on the car Paul?
Old 10-18-2012   #47
51,1xx miles.
P.
Old 10-18-2012   #48
51,1xx miles.
P.
I was using the same amount of oil on my 91 in the 60K range.
Old 10-18-2012   #49
Whew... Well, that's comforting. But, I'm sweating the (near???) over-heating episode now...paranoid, I recon. Long as the gasket held (again), I guess I'm alright. $$$ is really tight right now, and I really hate to see what the compression test might show. Then again, the courageous only die once, and a coward dies a thousand deaths. I guess I'll get it over with! It would be a "bit more" than a winter project to fix the short block…
P.
Old 10-18-2012   #50
Daniel_Mc
Daniel_Mc's Avatar
P.
Paul,
The 91 was doing this when I got it. It would spike to right at the hashed section and this worried me. The PO told me it "did it sometimes" and that he had Marc check it and clean the radiator but that it didn't help due to the wiring from the battery being too small to run the fans at idle (or something like that). But this was happening going down the road... Well I went to looking and the WP was leaking and the radiator clogged. Once all of that was repaired (new WP and removed and cleaned the radiator) the Z stays nice and cool now. Anyhow point being I think our Z was done that way for a long time so I think you are safe if it just did it once on yours.
Daniel
