Old 11-03-2013   #13
Pat Cooke
Default Re: ROUGH RUNNING 2
Fuel pressure leakage, either FPR bladder rupture (allowing fuel through FPR vacuum tube), or leakage from leaking injectors, can cause hard hot restart.
Cold start would still be easy with fuel leak, because fuel readily atomizes in cold environment - think Cold Air Induction.
Chilton's should have a round hollow binder, and should hang in the 'library', where the chair has a big hole in the middle. Tear a page, read, wipe, flush, repeat if necessary. 'Krinkle', between 'read', and 'wipe', if you're tender in the hindquarters
Re : Chilton's, I have ordered a GM FSM.
I will be doing the fuel pressure test.
Thanks again !
Pat Cooke is offline   Reply With Quote
