Old 11-03-2013   #11
Pat Cooke
Default Re: ROUGH RUNNING 2
Nice to hear from you again. Yes, I am going to do some more diagnostic work before buying parts. I don't have a GM factory manual, I do have a Chiltern repair manual, a GM service manual supplement LT5 and GM 1990 section 8A electrical diagnosis. I am thinking of buying a multimeter and an OBD1 scanner cable and software to connect to my laptop, from Red Devil River in Wisconsin. 111018956789 on ebay. Thanks for your advice,I would welcome more on your thoughts on fuel pressure leakage ?
Pat Cooke is offline   Reply With Quote
Old 11-03-2013   #12
Schrade
Fuel pressure leakage, either FPR bladder rupture (allowing fuel through FPR vacuum tube), or leakage from leaking injectors, can cause hard hot restart.
Cold start would still be easy with fuel leak, because fuel readily atomizes in cold environment - think Cold Air Induction.
Chilton's should have a round hollow binder, and should hang in the 'library', where the chair has a big hole in the middle. Tear a page, read, wipe, flush, repeat if necessary. 'Krinkle', between 'read', and 'wipe', if you're tender in the hindquarters
Old 11-03-2013   #13
Pat Cooke
Re : Chilton's, I have ordered a GM FSM.
I will be doing the fuel pressure test.
Thanks again !
Old 11-03-2013   #14
efnfast
From what I understand, the pre 93 injectors will fail if you run alcohol through them. Do you in England? If so, sounds like it wouldn't hurt to change them, maybe to the wallet, but you're due anyway. Mine are in a box getting ready to go in. New SS FIC's.
Old 11-03-2013   #15
Pat Cooke
Thanks for your thoughts.
Old 11-03-2013   #16
Pat Cooke
Yes, I live in Cornwall, England. Great Car !
Old 11-03-2013   #17
Schrade
That's what Mr. W posted; most specific info I've ever known of about ethanol in fuel, solving the coil winding insulators...
VERY interesting.
Still say static FP + leakdown first..............................
ed.:
Wonder if anyone knows the different molecular compound in '93 + winding insulators.
2nd ed.:
Damn that's a good question Uh hUH...
