#191 |
Finish forward end; Shop-Vac to pull some loose bolt head jam
Wrap some steel wool around the A/C lines... Is there some filter / membrane in this opening? It's some kind of spongy mass, and looks full of cheesy motor nasties... ![]() Next up; get the Campbell's Chunky-Style juice from the SP wells... |
#192 |
Cam Cover Filter
But....you have to remove Cam Covers to install the Cam Cover FIlters. There is a wire clip that holds the Cam Cover Filters in place in their respective slot in the cam covers (inside the Cam Covers). The wire clip extends through two small holes in the slot sides to keep the filter positioned to the top of the Cam Cover. I have removed Cam Covers and painted them with engine in car ![]()
Clickable links ![]() On Iphone Touchable Links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 11-07-2013 at 08:03 PM. |
#193 |
More Gloss Red ?
Does anyone have painting / Powder coating on their aluminum piping? Like the CC vent pipes on back of the IH's? Or the vent pipes connected to the Cam Cover fronts? Or even the skinny coolant pipes that 'T' from the plenum??? Cliff? Got snappics of colored lines? |
#194 | |
#195 | ||
#196 | |
Removing Cam Cover and Camshaft Timing Inspection Cam Covers (Filters and Wear Strips)
Clickable links ![]() On Iphone Touchable Links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 11-08-2013 at 07:49 AM. |
#197 |
I'm not gonna' pull the cam covers. I'm in deep enough, and hardly knew what I was doing to start with. Really.
But the vent system has me intrigued. Something about all those vapors coming through that little filter membrane. I'm gonna' investigate routing them, joined, up front, to the K & N, to be the 'catch can', if possible... Opinions hereof??? So if there was any question about the Red coolant manifolds being obnoxiously Red (never could decide about etching color), I answered THAT question with the brush last night. yeah - there's a couple of glossy pipes in there SOMEwhere: And I'm here ta' tell ya'; mixing the hardener / paint brew is gettin' old....................... Last edited by Schrade; 11-08-2013 at 11:35 AM. |
#198 |
![]() Join Date: Jun 2004
[QUOTE=Schrade;187487]So if there was any question about the Red coolant manifolds being obnoxiously Red (never could decide about etching color), I answered THAT question with the brush last night.
QUOTE] Your last email left the engraving to be painted in Yellow bowtie and black LT-5. Anything change since then............ ![]()
#199 | |||
Out of town now................................... WHat adhesive is best for re-attaching the C4 emblem to the CC??? Last edited by Schrade; 11-08-2013 at 05:57 PM. |
#200 |
![]() Join Date: Sep 2013
Man your doing a great job. Try some of that two part epoxy to glue that emblem back down. Read the labels on the epoxy at the local car parts store. Surely they have something that will bond plastic to lumineee
