Old 11-11-2013   #1
Pete
Pete's Avatar
Default Pulleys
Hi Guys
I will be ordering aluminum pulleys Power Steering, Water Pump.
Colors are Black,Blue,Red,Silver.
These are half the weight of stock steel pieces.
$199 each + shipping
I can do checks or paypal add $6
Please post I would prefer email: petezr1@gmail.com
PS pulley/WP pulley or both and color.
Thanks
Pete
'91 #1635 PoloGreen 350 LT5
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 11-11-2013   #2
Default Re: Pulleys
Stock sizes? OR?
Old 11-11-2013   #3
Default Re: Pulleys
Have both of these and yes there are very light. In black, can't tell them from stock.
Old 11-11-2013   #4
pantera1683
Default Re: Pulleys
Just curious, what benefit are the lighter pulleys?
Old 11-11-2013   #5
Default Re: Pulleys
Lower rotational inertia in addition to less weight.
Old 11-11-2013   #6
Default Re: Pulleys
Stock sizes? OR?
Old 11-11-2013   #7
pantera1683
Default Re: Pulleys
Yeah, but are we talking about a measurable hp difference?
Old 11-11-2013   #8
Default Calculations
Zero additional hp. Just like a lightweight flywheel.....a light weight flywheel and/or lightweight pulleys driven by the harmonic balancer allows quicker engine acceleration which in turn allows you to get to a higher engine hp output quicker.
In other words......you reach 7,000 engine rpm quicker which multiplied by torque is Horsepower. Omega X T where Omega is Radians per second and T is torque in ft lbs......
550 ft-lbs/sec is one horsepower. Take a look at L98 Frisbee Horsepower below
Tech Info - LT5 Horsepower and Torque Calculations
Tech Info - ZR1 Differential Gearing and Vehicle Speed Calculations
Tech Info - ZR1 Wind Force, Rolling Resistance, Drivetrain Loss Calculations
Tech Info - LT5 Camshaft Timing Calculations
Tech Info - LT5 Pressure Drop In Oil Lines Calculations
Tech Info - LT5 RC SL4-205 injectors (500+ hp) Calculations
Tech Info - L98 Frisbee Horsepower
Tech Info - LT5 Coolant Flow Calculations
Old 11-11-2013   #9
Default Re: Pulleys
So if F=ma, w A being increased, then you have a greater force but you've also reduced the mass. A wash?
Old 11-12-2013   #10
Default Re: Pulleys
NOT
a=F/m where a is vehicle acceleration and m is mass of ZR1.
F = Wheel Torque divided by wheel rolling radius. F increases with engine rpm and increases faster if engine rpm increases faster by reducing pulley inertia. m decreases by reduced pulley weight albeit such a small percentage as to be Negligible.
Keep in mind these pulleys have the largest part of their inertial resistance......The fluids they are pumping such as water and power steering fluid.
All that being said true meticulous, fastidious, picky perfectionists like some of us install these pulleys on all their Zs (me included)
Pete is offering aluminum pulley colors (Colors are Black,Blue,Red,Silver) not offered anywhere else. I am assuming these are Powder Coated or better yet (anodized) colors.
