Picked up a 90 last month had it running great for two weeks after replacing the injectors. Now with key on engine off my pump was cycling so I pulled the plenum back off. Looks like the vacuum solenoid is leaking bad anybody know where I can get a replacement?
________ 90 white/grey #2011 |
![]() Join Date: Dec 2003
Congrats on the ZR-1 score.
Info >>http://www.corvetteactioncenter.com/...0/002/article/ the part is >> Vacuum Solenoid with conical air filter (Part #1997222) We will see what others say for where for you to get one at. Welcome to the Brotherhood and the Zoo. Use the solutions thread for problem investigations and suppliers >> http://www.zr1.net/forum/showthread.php?t=11619
http://i119.photobucket.com/albums/o...9mcw/SIG-2.jpg http://i119.photobucket.com/albums/o128/wb9mcw/vcm.gif "The Budget should be balanced, the Treasury should be refilled, public debt should be reduced, the arrogance of officialdom should be tempered and controlled, and the assistance to foreign lands should be curtailed, lest Rome will become bankrupt. People must again learn to work instead of living on public assistance." - Cicero, 55 BC " We the people are the rightful masters of both Congress and the courts, not to overthrow the Constitution but to overthrow the men who pervert the Constitution." - Abraham Lincoln Last edited by WB9MCW; 10-24-2010 at 02:17 AM. |
![]() Join Date: Dec 2004
I think that you can still buy one at the chevy store, no? If not either hit up either of these links:
http://jerrysgaskets.com/store2/root/ or: http://whiteracingproducts.com/ Those guys will be able to fix you right up. ![]()
![]() Join Date: Nov 2006
I went thru the same problem, Delco # 214358 works after minor bracket change ($20) also cross GM# 1997212 if nec? Make sure check valve is good (I missed & had to pull again) if nec a small check valve at plenum (drivers side) will work. The fuse for pump should be #17 / valet on dash pass. side.
Let us know how you do.
Gene in Fl. :handshak: ______________ 95 ZR-1 #399 Dunn heads X-pipe w/3" misc. mods |
I looked at Jerry's website yesterday, didn't see any. White racing has one in a kit $620 ouch. Might need to call them and see if I can just buy the valve.
#6 | |
Could you double check that Delco # I could not pull it up on GM Parts direct.
Thanks for the help Never mind, found it thanks. Quote:
________ 90 white/grey #2011 Last edited by Mr Cool; 10-24-2010 at 02:17 PM. Reason: found it |
Holding the box in my hand, ACD# 214-358 with GM# 1997212 shown on the lid. Call me if you like to discuss the process I followed 407-391-9492.
I found it. Thank you
#9 | |
![]() Solutions >> http://zr1.net/forum/showthread.php?t=11619 Would be great for members in the future to be able to do this and $ave. ![]()
http://i119.photobucket.com/albums/o...9mcw/SIG-2.jpg http://i119.photobucket.com/albums/o128/wb9mcw/vcm.gif "The Budget should be balanced, the Treasury should be refilled, public debt should be reduced, the arrogance of officialdom should be tempered and controlled, and the assistance to foreign lands should be curtailed, lest Rome will become bankrupt. People must again learn to work instead of living on public assistance." - Cicero, 55 BC " We the people are the rightful masters of both Congress and the courts, not to overthrow the Constitution but to overthrow the men who pervert the Constitution." - Abraham Lincoln |
#10 |
Finally got back to working on the car today. I got the solenoid Belsy suggested, and swaped mounting brackets with the original. Now all is good again. Thanks. Guess I'll let my wife (it's her car) drive it for awhile before addressing the next problem.
