Old 08-15-2010   #11
Pete
Pete's Avatar
Default Re: Building an LT5 engine harness from scratch. Any advice?
Originally Posted by shanker View Post
Yes I do. I won't be needing it though.
Please keep us informed.
Let us know how you get away with the secondary modules and how you'll det the ignition to work.
Pete
'91 #1635 PoloGreen 350 LT5
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 08-15-2010   #12
shanker
Pete,
The ignition can be set up using 4 Bosch type ignition modules (one for each coil pack). They are small and inexpensive. The Autronic ECU has 4 ignition outputs which will tell each module when to charge and fire the respective coil packs. These 4 Bosch modules are small enough to mount under the intake.
The Autronic ECU can control 16 seperate injectors. I will be running the primary injectors full time, and the secondary injectors will be disabled at idle, and kick in at 1% throttle.
Of course, this is all easier said than done!
shanker is offline   Reply With Quote
Old 08-15-2010   #13
Pete
Pete's Avatar
Pete,
Shanker you da man.
If you get it to work,could you get a complete package togather basicly plug and play i would be interested,let me know how much $$$.
This way i gaet rid of CCN BCM and the rest of the crap.
Those Bosch ignition modules a common part at part stores.
Also is the Autronics ECU tuneable with a laptop?
Pete
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 08-16-2010   #14
DaveK
It appears to be, they have tuning software available on their website.
http://www.autronic.com.au/
Dave
1991 #1516 Black/Black
davidmkelly.com
Old 08-16-2010   #15
shanker
my Autronic SM4 unit is fully tune-able with a lap-top. it can log data from track time, and has a number of really cool features that I probably won't use on this project, like turbo anti-lag that spools your turbochargers up fast when you mat the gas out of a corner.
it's also equipped with "flat shift". This allows you to change gears without lifting off the throttle while a secondary rev-limiter keeps the engine at the ideal RPM. This is accomplished with a simple pressure switch on the clutch linkage, like a brake light switch.
The Autronic units are also unique in that they have an auto-tune function that uses the input from all the engine's sensors to tune itself while you operate the engin over all the RPM and load ranges. once the engine is self-tuned you can make the minor changes that you want.
It's also significantly cheaper thsn FAST or Motronic etc.
Old 02-05-2011   #16
todesengel
Have you thought about how you were going to read the crank and cam positions? I am not versed on the autotronic but most standalones will not read the 8+1 configuration on the lt5 crankshaft. Some also will not read the cps setup on the lt5 as well. Do you plan to run an external trigger wheel? I am welding the 9th tooth on the crank (the one that is not evenly spaced) closed so that it does not trigger the sensor.
Interested to see how your project lines out as I am doing something similar with mine, with exception to running a haltech p2000 platinum in place of the autoronics unit.
Does the Autotronics control your fp as well?
I am also running sequential ignition, as well as timed fuel injection. Pros/cons are debatable, and up to the individual to choose their own path imho.
Secondary injectors are going the way of the dodo and being replaced with meth injectors in their place. larger primaries will take care of the fuel.
Your harness build question perplexes me a bit. You have inputs/outputs and primary functions of the engine that must be taken care of. Your ecm should have a pigtail of sorts, labeled for each one of these functions. It is a simple matter of joining your sensors to the proper leads provided on your ecm. I may be oversimplifying the obvious, perhaps you could give more detail to your particular situation with the wiring.
It should be interesting to see how my zr1 registry labeled unimpressive system compares against your autotronics unit. If I can be of any help to you feel free to pm, I may not have the answer but I will try the best I can.
todesengel is offline   Reply With Quote
Old 02-05-2011   #17
ZR1@gmx.com
I have a new 93-95 Wiring harness FS if that would help!
ZR1@gmx.com is offline   Reply With Quote
Old 02-05-2011   #18
Can you tell us more about how Autotronics interfaces with the DIS module?
And if youbdon't need the secondary injector module, is the Autotronics driving each injector separately?
Old 02-06-2011   #19
shanker
This project has been moving forward, but mostly in the chassis & body department. I haven't touched the engine wiring yet except for purchasing all the necessary connector pigtails & getting wiring diagrams. I was originally looking for pinouts on each of the LT5's sensors, but I have that info now. Part of the reason I chose the Autronic Engine management is because I've seen it control the LT5 engine and it can use almost all of the stock sensor inputs. Crank & cam position sensors are usable with my autronic unit as far as I know.
I'm using an AEM brand CDI 4 channel ignition to fire my factory coil packs. I haven't heard anything bad about the "wasted spark" setup. I planned to use an external regulator & set fuel pressure at a constant.
todesengel: Using only 8 injectors sounds like a great idea! I'll PM you about which ones you're using, and what you use in place of the secondaries to fill the holes. I don't really need meth injection but I do need something in place of those injectors. Maybe just leave them in place without wiring them? I was told by a GM ZR1 engineer that I could run the FP at 55psi and I'd be happy with the results. the stock injectors are 22.8lbs/hr @45psi
I was planning to run all 16 injectors, and have the secondaries kick in at anything above 1% throttle. I was told this would give a good idle and performance. Basically I would wire primary & secondary injectors together, but use a relay for the power output to the secondaries. Both injectors for each cylinder would fire in unison above 1% throttle.
I am no expert and I have no real experience with the LT5 engine so if anyone has advice for me I will certainly appreciate it.
