Old 04-22-2011   #1
Scrrem
Scrrem's Avatar
Default Sway Bar Diameter
Thinking about re-bushing the Z. On the 90 ZR-1, what are the sway bar diameters front/rear? From what I have been able to find online, I think they are 30mm front / 26mm rear. Is this correct?
Rich
1990 Bright Red Coupe #608
Coated SW Headers / Corsa
Ron Davis Radiator
Pioneer AVIC-Z140BH NAV
Old 04-22-2011   #2
Aurora40
Aurora40's Avatar
Default Re: Sway Bar Diameter
Those are the Z51 sizes.
26/26 according to this:
http://corvetteactioncenter.com/tech/c4/susp_chart.html
Old 04-22-2011   #3
Scrrem
Scrrem's Avatar
Cool, Thanks Bob!!
Ron Davis Radiator
Old 04-22-2011   #4
QB93Z
QB93Z's Avatar
Hey Rich, let me know if you need some help with that project. Jim
Old 04-22-2011   #5
Scrrem
Scrrem's Avatar
Will do Jim!!! Thanks!!
Rich
Ron Davis Radiator
Old 04-22-2011   #6
lbszr
lbszr's Avatar
This one says 26/24 http://www.zr1netregistry.com/ZR1_suspension.htm
I'll have to go out and mike the rear, mines probably original.
Old 04-23-2011   #7
Aurora40
Aurora40's Avatar
Would be interesting to know which it is. Only reason I'd think they might use a bigger bar than the base suspension is to offset the understeer caused by the bigger rear tires and (slightly) stiffer front spring?
Old 04-23-2011   #8
Scrrem
Scrrem's Avatar
I'll take a rough measurement today, see of the front matches the back diameter.
Rich
Ron Davis Radiator
Old 04-23-2011   #9
Scrrem
Scrrem's Avatar
Rich
Well the front sway bar is larger that the back, so I would say it's 26/24.
Rich
Ron Davis Radiator
Old 04-24-2011   #10
jrtoffroad
Measured my 91' the other day...26/26
jrtoffroad is offline   Reply With Quote
