Old 04-27-2011   #21
rhipsher
rhipsher's Avatar
Default Re: 1990 Exhaust Manifold Passenger Side Flange???
This is what it looks like on mine.
Old 04-27-2011   #22
Blue Flame Restorations
Cool. Thanks! Collector with a clamp.
1990 ZR-1 #444 Convertible
1990 ZR-1 Black #966
1991 ZR-1 Quazar Blue #296
1957 Duntov SS Project
Old 04-27-2011   #23
All 1990-1991 have a ball end on driver side and triangle flat flange on passenger side.
Lee has a 1992 they have the slip fit on the passenger side.
Pete
Those pics are of my 90
Old 04-27-2011   #24
mike100
Some of the larger diameter cat-back exh systems had a slip over pipe with a triangular flange. My car came with a 3" B&B setup and had a 2-3/4's adapter pipe to a 3" flange. It was welded permanently.
I had to have a mating flange welded up on my Corsa. I prefer it this way anyhow because the slip fit might leak or be difficult to align at some point.
Old 04-27-2011   #25
Pete
Pete's Avatar
Lee, previous owner probably took it off.
Pete
'91 #1635 PoloGreen 350 LT5
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 04-27-2011   #26
rhipsher
rhipsher's Avatar
When my cats went bad and I had to replace both manifolds I had to beat that collector/flange with a rubber mallet damn near 100 times before I got it off. That thing was on there good.
Old 05-18-2011   #27
HAWAIIZR-1's Avatar
Hello Brett,
I just found this after posting a WTB for this part you were looking for too. Were you able to the part you needed from Marc? It seems just like a typical header collector, but I don't find it in 3" to 2.75"; maybe I just get one of those and open up the 3" to
2.5" to 2.75" to slip over the pipe?
Thanks,
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
NCM Lifetime Member #2048
Old 10-12-2012   #28
ZR-91
Originally Posted by dscott View Post
Brett,
The gasket part # is 10147973 from GM. I'm not sure if this is still available. If it not I have a couple available.
Do anyone know where to get this gasket?
ZR-91 is offline   Reply With Quote
