#121 | |
It appears that there's a leak from the oil temperature sender, which I had resealed with teflon tape a few months back - and apparently that's not the correct method. The FSM calls for Loctite 565 on these fittings, so I've ordered some of that and will also re-seal the oil cooler fittings with this correct material. The teflon tape does not appear to hold up well to hot oil. |
#122 |
#123 |
Andrew any luck ? Daryll
#124 |
#125 |
![]() Join Date: Dec 2004
Ouch! I know how that feels. I've lost three 315's over six years to screws going thru the tire.....it just seems like it's the little things that come along every now & again to make our day an enjoyable one!
#126 | |
I hear that lost a few the same way. Those big tires have a big footprint. Let hope everything else is smooth sailing Andrew
#127 |
![]() Join Date: Jul 2007
Hey VetteMed,
how are you liking that Arc Audio Mini amp? I am looking to swap from my Arc 300.4 to the same one you have, mainly due to space constraints.. what are your opinions on that amp of yours?
#128 |
Update:
I pulled the plenum once again, to finally get the A/C system up and running. When I pulled the rubber evap vacuum line off of the hard line, I got a handful of black granules. I shook the rubber line, and got a whole bunch more. Turns out the charcoal canister behind the rear wheel took a crap, and sent charcoal all through the line and presumably through the solenoid and into the intake. I'm hoping it didn't score up any cylinder walls too badly. |
#129 |
Jeff, now that I relocated it out of the storage compartment, it's doing well. it was getting entirely too warm in the compartment. However, I'm only 5'9" so I tend to keep my seat somewhat forward, leaving plenty of room for the built-in fan to cool the amp when mounted behind the driver's seat. It's very powerful and clean for its size.
#130 |
Damn, I had a chance at 2 to replace my bigger Arcs and I passed, ah well, I can deal with what i have.. LOL
