Old 06-01-2011   #11
jrd1990zr1
jrd1990zr1's Avatar
Default Re: Need Part Badly GM Part #1997222
Jeff,
I've got a new design (round) filter. Looking for a source for the solenoid.
Thanks, John
1968 convertible Lemans Blue,
1986 coupe Medium Blue NCRS Top Flight (sold),
1990 ZR1 #2529 Red NCRS Regional and National Top Flight (sold),
1990 ZR1 #2124 Charcoal Metallic NCRS Top Flight 2010 & 2018,
2003 Anniversary Red Convertible (sold)
Old 06-01-2011   #12
Originally Posted by jrd1990zr1 View Post
John,
Sorry about the reply to a very old post. I've got to ask, were you able to make the new style ACDelco 1997222 work on your car??
Thanks, John
Im a little lost here John.The new style #1997222 works in place of the origanl design and will have 3 nipples,2 are for the vacuum plug-fitting and the one nipple on the opposite side is for the filter.The one I got off Fleabay from Jim Butler Chevrolet.The Kodiac truck uses the same vacuum pump and I read somewhere that this truck might use a similar solenoid.Theres a thread here somewhere thats got a new part that will work for these cars.
Old 06-01-2011   #13
ScottZ95ZR1
ScottZ95ZR1's Avatar
PM sent John.
ScottZ95ZR1 is offline   Reply With Quote
Old 06-01-2011   #14
ScottZ95ZR1
I've read threads that reference both part numbers 1997201 and 1997212 as suitable solenoids for use with conical filter part number 10159525.
Old 06-01-2011   #15
I just Googled the #1997222 and pulled up the valve at $27.00,I need to buy another one while they last.Heres something to think about.When I got this valve I went down to the dealer to get the correct filter based on the correct part# I got from the parts diagram I have,clearly shows the round filter.I paid $8.00 and ordered it.The filter that came in was the small square filter.The guy at the parts counter swore up and down that this was the correct filter and would not give me a refund on a special order part.I cant remember how I got the right part but the parts guys wasnt too happy.
Old 06-02-2011   #16
limey
Order GM part # 1997225, it's the closest thing to the OEM design and works perfect. Autozone should stock it too, about $25.00 or so.
limey is offline   Reply With Quote
Old 06-03-2011   #17
Hammer
Hammer's Avatar
Talking Re: Need Part Badly GM Part #1997222
Sorry for the lapse in answering.
I got the three port solenoid and bought the filter for it. Works good so far but the vacuum pump is working about every 2 seconds sometimes. I put a loop on the outside of the plenum and it stops so the friggin' check valve is not holding as it should.
Old 06-03-2011   #18
jrd1990zr1
jrd1990zr1's Avatar
Jeff,
GMPartsdepartment.com shows them in stock at 25.81. After you order it and submit your credit card they say it is discontinued and cancel the order.
2nd time they did this to me on a part. They need to update their website or give a telephone number to check stock before your order.
Sorry about the rant.
