07-16-2011 | #1 |
Fuel injectors
Hi
Anyone have a good source for original 90 ZR1 primary and secondary injectors and their respective part numbers? many thanks
Red/red 90 #1281 (UK) Marc Haibeck 368 B&B, Brembos DRM suspension Known as 'Gixer' on corvettechat.co.uk www.corvetteclips.co.uk |
07-16-2011 | #2 |
Re: Fuel injectors
Injector replacement....
Do not use OEM injectors! http://fuelinjectorconnection.com/sh...ewCat&catId=68 Get Stainless Steel ones that they make and not the rebuilt ones. David |
07-18-2011 | #3 |
Re: Fuel injectors
I have a full set of (8) original OEM secondary injectors new still in the boxes that I am willing to sell. These are straight from a GM supplier, probably some of the last available. My car sits for extended periods and I will eventually change out to the stainless injectors referred to in above post/thread. Email me at reddog382ft@aol.com if you are interested.
Chris
Enjoy the View! |
07-19-2011 | #4 |
Re: Fuel injectors
OP is not in USA, may not have ethanol subsidy in the UK - OE parts may be just fine.... - Jeff
