#31 |
Did we ever finalize a status on using the CTS-V or Camaro brakes?
#32 | |
![]() ![]() Join Date: Feb 2010
Looks great, Dave.
#33 | |
Here's my car with two-piece rotors and the 6P caliper. I had about $2k total into the brakes: The rears are "plus" rotors, they are 13" vs 12", and come with a caliper relocation bracket. It was only $50 more (on ~$500 rotors) for the "plus" upgrade once I decided on two-piece ones. I'll tell ya, I really miss how good that car looked... |
#34 |
![]() Join Date: Dec 2005
The C6 ZO6 fronts were a staight forward set up, simple adapter. I bought the new front calipers & rotors form a forum member for $450.00 shipped from VA. (great deal) The rears I had to pay small discount retail, I beleive $600.00 cals & rotors. Hawks pads, extra as well as new SS lines. The rear hub adapter was another $600.00 + & I needed to get some new C5 e-brake cables to make it work. Once I put the fronts on I had no choice but to step up and do the rears(the caliper was to small sitting in the wheel) I am more than happy with the final result eventhough it cost me a little more coin. Like Dom I run the OEM ZO6 wheels. I will be at Carlisle on Friday morning if you want to take a look
#35 | |
So you run an 18" wheel? I plan to run my massive Dymag GenII's 17x11 front and 17x13 rear wheels. I think my max size rotor is a 13"??? Right???? Probably do the C5 Z06 calipers with adapters and anything else I need to make it work. It would be nice to have a parts list of everything I need to make this setup work before I go to Carlisle. Anyone have a quick list?
#36 | |
![]() Join Date: Jul 2004
C5/C6 Calipers C5(C6?) Abutment Brackets C4/C5 Adapter Brackets C5/C6 Rotors C5/C6 pads Thanks Dave
1991 #1516 Black/Black davidmkelly.com Author of fast-paced, sci-fi thrillers. |
#37 |
Here are C6 base base calipers powder coated red and 2 piece rotors I got from Ricky when he went the C6 Z06 route.
#38 | |
Phil, are you running a 17" wheel or 18"". If I run a 17" wheel, what is the largest diameter rotor I can run? 13" ??? So, can I run a C6 caliper with a 17" wheel. If so, what size rotor am I limited to running???
#39 | |
1* Caliper C5 '97-03 Base LT Front 1** Pads Z06 Front '97-04/ 1** Pads ZR-1 OEM Rear '89-96 2 Pad Abutment Bracket / 2 Rebuild Kit Rear Caliper / 4 Guide Pin / 4 Rubber Boot Kit/ 2 Banjo Bolt Fitting 1 Copper Washers-10ea / 1 Theadlocker Red Permatex-High Strength 2 front rotors 2 rear rotors 1 C4 Brake Bias Spring 1 Earl's Hyper-firm SS Lines '93-96/ 5 Valvoline Synpower-Synthetic Brake Fluid 4 Calipers/Brackets Powdercoated 1***C4/C5 Adapter Kit / / / 125.00
#40 |
Thanks, Kevin. That helps tremendously.
What is the rotor size with this setup??
