#1 | |
![]() Join Date: Nov 2007
Moving from hypothetical to empirical LT5 (secondary facts and characteristics), I found these departures from the "textbook" as you may soon discover (hopefully):
I don't know what significant information can be gleaned from the results of these drastically different motors, but in the context of the general discussion, I thought they'd be interesting in their respective right, no? My stock LT5 (note the leaning was due to the secondary fuel pump failing) ![]() This is the same motor after being fully ported according to "FBI" models that demonstrate proven characteristics I particularly like. ![]() And, rules and theories and empirical data that apply to 2-valve motors struggle to apply absolutely to 4-valve, dual intake runner motors - or at least to the LT5's design. For comparison, look at the characteristics of a stock(?) LS7, the torque and power curves in particular, compared to the (350 ci) LT5. ![]() For a comparison of an LT5 a bit closer to the LS7's cid, there is this: a 415 cid (stroked and sleeved) LT5: ![]() I've rambled too much (as I tend to do..) P. |
![]() Join Date: Jul 2011
Paul... Thanks much for the data. Haven't really done the math, but my gut take is that its pretty much as I expected, though the scaling of the first 2 graphs is a bit different. From looking at the shape of the curves, the modified motor has a lot more midrange torque and relatively less torque at the bottom end. The base motor seems to make about 280 ft lbs at 2000 and peaks at 330 or so, which is 16% higher. The modified motor starts at about 300 ft lbs and peaks at 377, which is 26% higher.
As to the injectors, I have to look up the model number you mentioned. I am used to thinking of injectors in terms of how many cc's they flow, like 850cc Bosch's or 1600 cc Bosch's or whatever. When I use a larger flowing injector that I want to work down low at lower pulse widths, I like Injector Dynamics modified Bosch's, because the take the pinhole and run it out through 6 channels, like the spokes of an umbrella, so the fuel is better atomized, which helps at low rpm and low duty cycles. I'm not an engineer, but read a lot and talk to motor builders a lot over time, so I can't quote Helmhotz. ![]() Most of my better experiments have been done with an E30 M3 piston engine and 2 and 3 rotor rotaries, all NA motors. Definitely spent more than a college engineering degree on my learning process! I agree about getting a flat torque curve, though I'll say that my old Ferrari 512 had more torque up high than down low and it really gave it a bike-like kick! Sorry for all this talk, since I don't even have a car yet, but, honestly, this motor is just such an exciting design that I can't help thinking about it. Gordon Gordon |
Gordon,
What the hell are you waiting for? ![]() ![]() |
#4 | |
Ya might as well get off the sidelines and get your feet wet. Oh, and bring some cream for that permagrin you're gonna get! ![]() P. |
