Old 07-31-2011   #1
ZR1@gmx.com
Default WWYD? (What would you do?)
I have to get a hood and have it painted to match my car... I have a white car and a white powder coated engine. I am thinking about having the hood painted white inside and out. What are some thoughts?
ZR1@gmx.com is offline   Reply With Quote
Old 07-31-2011   #2
Default Re: WWYD? (What would you do?)
If it was my car - no.
Serp.belt throws up a bit of grease and rubber dust. Keeping it clean would be tough. Also, a lot of underhood - frame, inside fenders, cowl, etc... are all flat or satin black.
Old 07-31-2011   #3
i'd leave it black
Old 07-31-2011   #4
carter200
carter200's Avatar
Black.................
95 ZR-1
BLK/Gry
#392
LT5 Reg# 868 *RIP*
ZR1NET Founding Mem #155
Old 07-31-2011   #5
WVZR-1
I wouldn't think it wise! The preparation required to do a "finished color/clear" to the backside of a hood would be tremendous. The black is a match to the balance of the engine compartment and I would think complement the "white PC'd engine".
Is the engine a "color match" to the car finish? I'm guessing not and it would become a more obvious mismatch with the hood backside colored to match.
Old 07-31-2011   #6
ZR1@gmx.com
Great advice! I think you have set me on the right path! Thanks!
Anyone have a hood????
Old 07-31-2011   #7
Ccmano
I saw a red one the other day that had the inside painted red and glossy. Looked really good. But must be alot of work to keep clean.
H
Old 07-31-2011   #8
ZR1@gmx.com
H
I would like to see that! I am surprised how easy it is to keep my white engine clean! Was thinking I could do the same with the hood!
Old 08-01-2011   #9
RICKYRJ1
RICKYRJ1's Avatar
I feel you need to keep it black for some contrast. You would have to much white going on and it will wash out your engine. The white (bad ***) engine is highlighted by the black. You can try a mock up if you want to see for yourself.
Old 08-01-2011   #10
bobbyhi
bobbyhi's Avatar
You have the same paint scheme that I do. I had the hood taken off and wet sanded and cleaned. Then had it painted gloss black with a red ZR-1
logo put near the top center. Really looks sharp. I have a couple of pics but don't know how to get them over here. I'll work on that tomorrow and post the pics.
