Old 09-21-2006   #1
phrogs
phrogs's Avatar
Default parts parts parts!
single 1990 LH cylinder head with valves no cams no lifters this is used 30,000 miles $1000 OBO
I have a LT5 motor that is a great candidate for a end table like you have seen pictures of this is a 350 hp block (never check vin for year) it has 3 spun crank bearings (Block is salvageable per some but wouldn't be cheap to fix), comes with a good oil pan, one damaged 90 RH cylinder head that would need some welding (cam chain let loose it can not be repaired to be a good cyldhead), and a LH head that has a mismatched cam cover, also comes with a 90 plenum but it has the map sensor mount cut off , and the front timing cover this would all be great for a display or a cut away I will also include good pistons and liners nothing else is included in this sale if its not mentioned above Its not included with the motor, Does not come with all original hardware to bolt it together I will include head bolts and old torx cam cover bolts but that's all I have. you would need all the other parts to make it a complete engine. $2500 for all the above I would bolt it together for shipment with some standard bolts but just enough for shipment.
91 engine harness, It is missing the black plastic coverings and has a few connectors missing, I know the O2 sensor connectors are gone there are a few others I think they were removed for splicing another harness, I don't know where they went I received the harness with a parts car other than that this is a good harness $250
93-95 oil pump $350
93-95 oil pan gasket $75
93-95 front cover gasket $75
these are from kurt white at whiteracingproducts, never used brand new
90 radio bezel cover $200
90 power key switch with key $150
DIS module the one that is under the plenum used $400
set of 1991 Red sport seats taken out of a 15,000 mile ZR-1 that was rolled over, In good shape they have some small marks on them scratches in a few spots but no tears and the bolster looks good. $750
91 CCM central control module taken from the above car $250
power seat tracks in good working order I have 2 available $150 each
dana 36 rear end with batwing have to check on the ratio ask and ill get it. its a low one 2. something $300
ZR-1 driver side door has some fiberglass damage $250
ZR-1 rear bumper damaged would be good for a wall mount but it has tears and is warped in a few places but would be great for a wall mount $200 obo
90 power antenna $50
please email me or call with any questions if I don't answer my phone please leave a message I will call you back.
I am a US marine I fly aircraft daily so I will miss calls
I can get pictures of any item you want so please ask for them.
JOHNNY P
Currently own
Old 09-23-2006   #2
phrogs
phrogs's Avatar
Default Re: parts parts parts!
hey Im up for offers hit me up and we can talk some things im pretty firm but others ill bend a bit to move them I need to clean out the garage
come on I know someone needs this stuff
JOHNNY P
Currently own
Old 10-12-2006   #3
ammrpm
ammrpm's Avatar
Do you happen to have the drivers side rear wrap around bumper molding for the 91 ZR1?
I need one in good shape.
Aaron
ammrpm is offline   Reply With Quote
Old 10-14-2006   #4
Z Factor
Z Factor's Avatar
Aaron
Hello Aaron and welcome to the forum.
Old 10-15-2006   #5
ammrpm
ammrpm's Avatar
Thanks! I have been lurking for a little bit. I am still new to ZR1's, so I don't feel like I can contribute that much yet.
Old 10-16-2006   #6
phrogs
phrogs's Avatar
im waiting on word from a friend of mine I may be able to help you yet
JOHNNY P
Currently own
Old 10-16-2006   #7
ammrpm
ammrpm's Avatar
Thanks! I look forward to hearing from you.
Aaron
Old 10-26-2006   #8
90dr1
90dr1's Avatar
Looking for thermostat housing for LT5 (ZR1) engine call if available 316-708-3102
90dr1 is offline   Reply With Quote
Old 10-26-2006   #9
Z Factor
Z Factor's Avatar
Smile Re: parts parts parts!
Hello and welcome to the forum.
