#61 | |
![]() Join Date: Feb 2011
#62 | |
![]() Join Date: Jul 2007
Searched a bunch of parts stores today, nobody had the 550-011 I needed, so I used the 550-013 and ground them smaller on the grinder.. added the holes and they worked good.. hoping to start the reinstall later tonight.
#63 |
My ebay catch can was not removing all the oil coming through the pcv system as evidenced by oil traces in the hose at the connection to the plenum. I bought a water seperator for air compressors from Loews, modified it slightly and it seems to keep all oil out of the plenum. I passed CA emissions testing w/the oil catch system and using thermo wrap on my headers and CATS.
#64 |
![]() Join Date: Mar 2007
If you have the smaller diameter(alittle over an inch) breather holes, O'Reilly and most other stores stock Dorman 555-018.....it is a hair small, however using a 17mm socket you can expand it to a perfect fit by driving the socket into the plug
LGAFF 90 #966-150K miles-sold 92 #234-sold 1987 Callaway TT #17 1991 ZR-1 #1359 Last edited by LGAFF; 12-21-2011 at 07:42 PM. |
#65 |
For anyone doing a catch can - if the can does not turn the airflow a couple times, plus use a filtering material, it probably won't get all the oil out. On my can the air comes in the side of the can near the top and exits out the other side across from the inlet. Inside, there is a verticle seperator plate from the top of the can to about 1/3 the way to the bottom. This forces the incoming air to turn 90 deg moving down the can and then another 180 deg to exit at the top. I stuff the same filtering material in our cam covers in the exit side of the can to stop any remaining oil from the airflow. So far the the pcv connection entering the intake has been dry, and I find oil the catch can. Especially after a high rpm blast or two ----or three---- or----.
#66 |
I don't expect it to get all the oil out, but some helps
#67 | |
![]() Join Date: Nov 2007
As far as this discussion goes, if there is such a lip in the 90 IH holes, then I'm wondering if the convex Dorman (sp?) plugs might not be thus installed w/o trying to flatten them to fit before installing them? ![]() ![]() P. |
#68 |
![]() Join Date: Dec 2004
On the 91 I/H's that I have as spares there is no lip to stop the plug. You just have to eyeball it as you drive the plug to make sure you don't go too far in and have it fall into the cavity.
I am not sure what there is on a 90 I/H as far as a lip inside the hole. I never tried to pull out the plugs that were there from the factory. ![]() Tom
#69 | |
#70 |
I'm currently in the process of removing the secondary vacuum system from my wife's 91. I removed everything yesterday and had a good bit of oil in the IH, PCV lines, and Plenum. I have a catch can from Elite on the way and hope that takes care of the Plenum. I was surprised to see it had IH and Heads as pictured for the 90 MY. My guess is most of the early 91's got 90 parts installed.
