View Poll Results: Which Performance Chip do you have?
Corvette Consultant 5 1.68%
Doug Rippie Motors(DRM) 53 17.79%
Ebert's Engine Service (EES) 3 1.01%
Formato's FasterPROMs 0 0%
Jeal 4 1.34%
Leonhardt Automotive 1 0.34%
Marc Haibeck 182 61.07%
Marc Randolph 11 3.69%
Southern Georgia Corvette (SGC) 12 4.03%
Todd Pepmeier 4 1.34%
TPIS 0 0%
Vette Doctor 0 0%
Z-Industries 7 2.35%
Team ZR-1 3 1.01%
Corey Henderson (DynoTex Racing) 13 4.36%
Voters: 298. You may not vote on this poll
Old 09-25-2009   #91
Jim Nolan
Default Re: Which Performance Chip do you have?
I had my e-prom modded again. Nothing wrong with the Haibeck chip but when SGC did my engine work Aaron programmed it to meet the mods.
Old 09-29-2009   #92
AtsZR1
AtsZR1's Avatar
Aaron Scott...he has done all of the mods on my car...very happy with the results. None better!
2021 Stingray Z51 SGM
1991 ZR1 SCG Enhanced
1967 BB Roadster
1963 Split Window Coupe
1954 Roadster
AtsZR1 is offline   Reply With Quote
Old 09-30-2009   #93
SGC custom tune for the 415 build.
Old 12-01-2010   #94
Marc is Da MAN.
Good job on all the detailed ?'s Dyno you covered all the angles.
Old 02-03-2011   #95
I just realized that I could now vote in this poll....
I have a standard Marc Haibeck chip in my 90.....boy I still can't figure out why I waited 5 yrs to get one! Marc's cooling fan protocol is worth it!
Old 01-13-2012   #96
efnfast
Is there an easy way to tell if the previous owner did a chip?
Old 01-13-2012   #97
Hib Halverson
Remove the ECM, flip it over, remove the cover and look at the chip.
Also, if ship-shift has been disabled or the cooling fans come on at lower temperatures than stock are both clues that the ECM has an aftermarket cal in it.
Hib Halverson
Technical Writer
former owner 95 VIN 0140
current owner 19 VIN 1878
Old 01-13-2012   #98
efnfast
Thanks Hib. What should the chip look like? Skip shift is unplugged, but the light still comes on. Fan's seem to come on way hotter than I would like. My driveway is 3/4 mile long. At an idle down my dirt drive it seems to get real hot.
Steve
Old 01-13-2012   #99
Hib Halverson
They usually do not have the OE broadcast code stickers on them. Also, many aftermarket chips have a label with the vendors name on it.
If your 1-to-4 light still comes on and the fan strategy is as listed in the Service Manual, you likely do not have an aftermarket cal.
At this point, some of the best aftermarket cals come from Marc Haibeck. I think, he advertises on the Registry site. He has a web site at: www.zr1specialist.com
Hib Halverson
Technical Writer
Old 01-13-2012   #100
efnfast
Thanks Hib, I'll check it out. I've been to Marc's site often. He has helped me out on a few times via e-mail.
