Old 02-08-2012   #181
Blue Flame Restorations
Default Re: Update on my hi-miler Z project
Good price, Kurt.
1990 ZR-1 #444 Convertible
1990 ZR-1 Black #966
1991 ZR-1 Quazar Blue #296
1957 Duntov SS Project
Old 02-08-2012   #182
Originally Posted by VetteMed View Post
First concern - price. Money is very tight for me right now, some tax issues going on, plus wife is a full time student. I don't like to shop by price (that's the wal-mart mentality), but I have confidence that Kurt is going to be selling a good product.
Second concern - availability / convenience. The motor is available NOW, I want my car back on the road ASAP. Kurt's shop is only 2 hours from me, so it is close enough for me to pick up without shipping fees.
Kurt is taking my motor as a core. core charge $3500 otherwise, which is probably more than I'd get selling it on my own, given the high miles on it. That is minus the IHs, plenum, TB, and accessories - I have a hard time believing that my well worn block/heads/pistons/rods/crank etc would be worth any more than that to someone else.
From my view based upon this situation this is the best case scenario for Andrew. Case in point my car has been down since May of last year. For a stock set up with a whole lot of new parts makes this a pretty good solution. My rebuild has taken forever all because of mostly time issues along the way. This gets Andrew back on the road in the least amout of time possible
Old 02-08-2012   #183
Originally Posted by limey View Post
Guys,
we rebuilt the motor ourselves. Stock motor rebuilds are no problem, it's only when modifications and such are needed do i send the work out, or port work etc. Then i have Pete or someone do this.
The motor Andrew purchased from us is really a smoking deal and frankly i'm surprised more people don't go this route. When he sees the motor, he'll be blown away. It has BRAND new heads & all new cam cover bolts, new water pump, new sensors - new rings - bearings - oil pump, chains - wear strips, tensioner and on and on the list goes. No to mention, it looks brand new.
I don't think anyone can touch our price for the rebuild, but please correct me if i'm wrong.
I even warranty it too!
I wouldn't want to rebuild his motor for one simple fact, TIME FRAME. That's the only issue, we are small operation and rebuilding LT5's isn't something i do normally, more for the heck of it to be honest and just another product to have for sale. So i was to rebuild Andrews motor, look for a 2-3 month time, not to mention, i wouldn't guarantee that i could rebuild it for anywhere near the $4499.99 price, there would always be something to add to the cost somewhere, at least buying what he has, he knows what he's getting and it's ready now.
#'S Matching, well when the ZR-1 becomes a 6 figure $$$$ classic it may start to play out, but right now i don't think 99.9 % of people need to worry about this.
PS, I'll have a full rebuilt 93-95 motor ready shortly too $4999.99 on this one.
Yeah Kurt Hell of a deal
http://www.youtube.com/watch?v=vIRQf0S3oD0
Old 02-08-2012   #184
VetteMed
Thanks for your input, Kurt.
Old 02-08-2012   #185
VetteMed
A great thread (or just continue this thread) would be the coverage with photos of the engine exchange (details of removal and installation of parts from old enigne to new rebuilt engine).
I'll be documenting the process with photos, and posting them in this thread.
...That is, if I can stop staring at your sig picture.
Old 02-08-2012   #186
Pete
Pete's Avatar
Kurt,that is a killer price.
Lets not forget the labor of disassemble and reassemble of short block.
Pete
'91 #1635 PoloGreen 350 LT5
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 02-09-2012   #187
Brillo1990
I know what you mean, it's so distracting I have to go back and look at it again when I read more replies.
Brillo1990 is offline   Reply With Quote
Old 02-09-2012   #188
VetteMed
Spent a few hours with the car today, removed the transmission, bellhousing, and pressure plate/clutch disc.
Lots of dirt and grease inside the bellhousing - which I suspect is due to a leaking slave cylinder. There's a little weep hole in the rubber bellows of the slave, and it was leaking fluid quite readily when manipulated.
Slave bellows:
Bellhousing:
Black Tag ZF6:
Clutch disc, surprisingly good condition for the miles. I am going to have to look through the service records, I can't see this being the original clutch disc.
Old 02-09-2012   #189
VetteMed
Pressure plate, some heat discoloration of the surface, but not bad overall
New pressure plate, TOB, and clutch disc:
Clutch fork and ball stud, some wear on the ends of the fork fingers, and some wear on the surface of the stud where the fork pivots:
Old 02-09-2012   #190
VetteMed
DM Flywheel still bolted to the crank:
Headers, swain tech coated but I sprayed them with VHT Flameproof silver, as they were looking a little shoddy.
